hello, i have a forward facing plenium for sale.. it suits a rb20det ecc. It made over 300 horses @ the wheels with no problems. Its completely polished and in great conditon. I have pictures emai [email protected]
its basically the standard maifold with the throttle body moved to the front of plenium.
280 ono
Cheers justin
*****PICS FURTHER DOWN THREAD*********
https://www.sau.com.au/forums/topic/78115-rb20-forward-facing-plenium/
  • 4 weeks later...
sorry guys.. finally got pictures.. had a heap of interested..first in best dressed..suit a ECC aswell
Cheers guys
Justin
0422944604 if you keen
Justin
Hey mate, Im very interested
SMS sent
  • 1 month later...
wer does the accelerator cable hold onto ?? if you look @ one of the photos above..there isvacume pipe which has fallen onto the accelerator holder cable thingy..if you take a close look you will understand me..otherwise give me a buzz on 0422944604 and ill explain it bettter
were there any vacum lines blocked or removed? no all used
let me kno!
where u at? im in perth..no problems sending over east
Cheers justin
Edited by hurtinit
  • 1 month later...
  • 4 months later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
