the clutch thing has been brought up quite a bit and someting "Organic" has been recommended heaps. Do a search for clutch or 'organic', might give u some ideas. Lots of opinions and stuff on different clutches.
Got a nine button ceramic-ferride clutch and pressure plate fitted (2500lb clamp). All up fitted it cost me $800 (about $535 for clutch and p/plate before gst). It is quite nice to drive, not too instant on the takeup. Their website is www.xclutch.com.au . It bites quite nicely, I am currently putting down over 260rwhp (260 is where the power curve flatlined on the dyno with the old clutch) and it grips quite well. It might be worth having a look at twin plates as well. Although I have never driven one, the guys I have spoken to that have state that take up is very similar to stock. Twin plates seem to come up from time to time on the for sale section of this forum for around $8-900 up, for a second hand item which seems like a real bargain.
EDIT: oops, just noticed the website is under construction, their phone is 1800 258824 - and they do a few different types of clutch, not just button.
Thanks for the help Steve, do you know if they have a melbourne based shop? My car is only producing about 230rwkW, so that should be plenty... If they don't have a melbourne based shop does anyone know of a good clutch shop in melb?? Thanks
Edit:
OK, so i checked out some threads, and it seems that a Daikin Exedy Organic is the way to go, and ICE can do them in melbourne. A couple of questions:
1. where is ICE?
2. are there different clutch ratings for the Exedy? I've heard that they can be fully installed for around 800 bucks, but have seen some that the clutch kit alone costs double that.
Please help ;)
Ronin,
Mine was slipping and so i am having it replaced it with a R33 clutch plate with an R32GTR pressure plate, a good combination for 400+ bhp or so i am reliably informed and cost remarkably little. The car when i pick it up in January will be around 350bhp at the wheels and the clutch shoud be well up for it and more
Will find out on the 10th Jan:)
Paul
7 Dissik Street, Cheltenham,
Victoria, Australia, 3192.
Ph: 03 9512 7591
Heard lots of good things about these guys. go to www.whereis.com.au if u want to find out exactly how to get there from where ever u're coming from.
yeah, that's the one i keep seeing, Daikin Exedy Organic. I don't have one, hell, i don't even have a skyline, so i can't tell ya anything about them except a lot of ppl seem to recommend them.
cheers.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
