This is confusing the hell outta me :confused:
Ive looked at the firewall on my skyline and there doesn't seem to be anywhere to run some cable through....do I have to drill a new whole?
I don't really wanna drill a new whole incase there is something behind the sopt I drill and I puncture something....
I need to run some 4 gauge cable from my battery under the bonnet all the way to the boot, I have already run all other cables to amps, deck, speakers etc...now it just needs POWA :uh-huh:
........help!
https://www.sau.com.au/forums/topic/78238-running-cable-through-r32-firewall/
there are some rubber/foam grommetsthe go thru if your looking from the inside they are right up underneath the dash easier to get to them from the engine bay they are kind of triangular in shape just slip youe wire through there. if you still cant find it try tracing your other wires in the engine bay through the firewall and slipping it along side them. but there is definitly a grommet there that you can remove to feed it through
What you need to do is
1. In the car on the drivers side take of the kick panel (right foot side when sitting in the car) with this off you should be able to see the firewall and in the corner a large rubber grommet.
2. Jack the car up, front driver’s side wheel, take the wheel off. once the wheel is off you need to remove the plastic cover in the wheel arch. don’t take it all off as there are like 500 screws just what is nessacery to pull part of it down. ps. you might want to put some car stands to hold the car up instead of leaving the car on the jack
3. standing at the side of the car where you took the wheel off take the power cable and push it through the guard there should be an opening near brake booster side of the guard (back end of the guard behind the strut tower) just feel around under the guard to find the opening. once you have found the opening, push it through the cable should know be in the wheel arc where you pulled the wheel cover down. put your hand up there and find the cable and then push the cable trough the grommet you should be able to feel it at the back of the guard
4. the cable should now be inside the car.
if you have any probs i can pm you my number and a can talk you through it
if you need any pics i can get you some
Good luck
I found this:
http://www.skylinesaustralia.com/forums/sh...hrough+firewall
describing pretty much what mr 32 described, thanks all, will see if I can find that hole....is it easy to do with the wheel on?
you cant do it with the wheel on as you cant take the inner plastic wheel arc cover off. if anything it is easyer with the wheel off
There is no need to go under the car or wheel arch at all. The easiest way to run cables in the R32 is down the drivers side from inside the engine bay.
There is a triangular shaped grommet in the inner guard behind the shocktower beside the brake booster.
When you remove the triangular grommet you will see a large round grommet in the firewall
directly behind it. From inside the car this grommet is located high above the accelerater pedal.
Remove the driver's kickpanel for better access.
Poke a screwdriver through the round grommet, from inside the car, into the engine bay far enough so that you can use electrical tape to tie the cable to the tip of the screwdriver.
If the cable is thick a bit of rubber grease will help to ease the screwdriver and cable back through the grommet.
Feed enough cable through to reach the amp and run the cable under the edge of the carpet where the sill meets the floorpan.
where would that cable some out in the engine bay?, under the brake booster?, I can't see any grommet from the top of the booster!, unless I am just blind
hmmm. now thats my problem...I already have speaker cable, remote wire cable and 2 RCA's running down the drivers side, so I am gunna go over the back of the dash and run it along the passengers side....6m should get that done right?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
