Originally posted by Mud
Some bodgey Japense bastard had cut the wires on mine so that only the outside two tail lights illuminated.
All 4 would light up for the brakes though.
It was quite cool as no one could pick mine as a Skyline from a distance.
I have since re wired it so that I have the trademark 4 stove plates.
I couldn't bare bieng different, but I think clear is cool
LOL They do that for compliancing. Australian ADR only allow for one break light per side.
Yeah just wire it back up when your ready and away you go, hehehe
quote'They do that for compliancing. Australian ADR only allow for one break light per side. 'quote
i have been working in the import market for over 7 years. And i have never see this done for that reson. But some compliancing company's black out s13 corner light's and put in guard repeters, and some don't. I am in QLD but that should not make a diff to ADR's
Well all this talk of changing taillights on my black car there is pointless now, as I've decided to buy a winered r33, as the black car was apparently going to take quite a long time to get over here.
The new car is spotless inside and out (except for steering wheel is worn, it came with a pretty floral cover but i decided that it wasnt required)
it's 1994 m-spec with the only mod being a 3.5" kakimoto exhaust... i can pick it up on tuesday ... yay (now i gotta get the "R33" plates changed to red)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
