  • Replies 67
I'm in for Keros option. 45mins of seat time will be ample. you can then run 15min each then driver change, then you have 45min break. and you will need it after 15min flat out.
well if it goes ahead put me down for a team of three.
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1449389
ooops, I meant teams of 4 for 3 hours (like kero suggested). bit silly of me, I got carried away and posted team of 3.
I'm sure I could encourage one or two teams from the GTI-R owners club. hopefully.
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1449956
Last time i was there i did 70 laps...
I think it was 2x20 with a 30 lap final ... awesome experiance. Really took it outta me.
But yeah... I'd be happy to be in a team of 1 if we can get 10-15 min breaks between heats.
Otherwise yeah i'll go team of 2. :(
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1450766
Probably the best day would be a saturday (we will get the most people then). (Sundays people tend not to turn up).
Even like a late thursday night session i think would be good.
Morning / Afternoon / Evening??
It would have to be at least late august to give enough time to get numbers and i believe ec require $50 deposits from all drivers.
Definately need more clubs as the more people the better.. :cheers:
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1451426
I recon Team enduro 3hr with teams of 4. That way its $146.25 each (or $131.25 during the week) and we each get at most 45 minutes each.
This sounds like a PERFECT plan.
I'm in for this :uh-huh: :uh-huh:
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1452184
Anytime after this month would be good... Drift nationals is so BLOODY expensive... especially when it is in Adelaide!
Here is a calendar FYI (Please note that not all these dates and events are confirmed and may change or be cancelled at anytime without notice)
Sunday 17th July 2005 - SAU NSW Show and Shine (Mingara)
Sunday 24th July 2005 - NSW Motorkhana Round 5 (Awaba/Dirt)
Sunday 31st July 2005 - SAU NSW Drag Day with RENEW (WSID)
Saturday 30th & Sunday 31st July 2005 - TOYO Drift Nationals Rd 3 (Adelaide International Raceway)
Sunday 14th August - NSW Supersprint C/ship Round 6 (Eastern Creek)
Sunday 28th August 2005 - NSW Motorkhana Round 6 (Oran Park/Tar-Concrete)
Sunday 4th September 2005 - Fathers Day Cruise?
Sunday 4th September 2005 - NSW Motorkhana Round 7 (Oran Park/Tar-Concrete)
Saturday 17th September 2005 - SAU Putty Road Cruise (and sleep over?)
Sunday 23rd October 2005 - NSW Motorkhana Round 8 (Nirimba/Tar)
Saturday 29th & Sunday 30th October 2005 - TOYO Drift Nationals Rd 4 (Oran Park)
Sunday 13th November 2005 - SAU Observation Rally
Saturday 3rd December 2005 - SAU Christmas Party (La Porchetta, Central Coast)
Saturday 10th & Sunday 11th December 2005 - TOYO Drift Nationals Final (Melbourne)
https://www.sau.com.au/forums/topic/78368-go-karts/page/3/#findComment-1453300
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
