Hey guys, i had my second run in with the boys in blue tonight got done for a few things :P
One thing that has me a bit stumped is i got done for having something done to the area where my back speakers are.
i bought the car like that, and the policeman goes you'll need a engineers cert for that.
I asked him what the problem was and apparently they had to make room for the speakers or something and that it could affect my car during a crash if i get hit from behind or something like that???
Anyway how much do those things roughly set one back? i looked at a few of the nsw threads about it but prices may vary here?
Any help apprciated!
https://www.sau.com.au/forums/topic/78431-engineer-certificate/
Engineers are $500, you'll probably need to replace your parcel shelf if it has sections missing, ie bits have been cut out to make room for the speakers.
My car came with the most poxy "custom built" parcel shelf made of two pieces of chip board sitting on each other. I've built a schmik replacement that's as tight as a nun's ****, could I get dicked for that? :confused:
engineers reports vary in price from each engineer/workshop to the type of modification/car... i dunno how you guys came up with these figures..
get a list of vicroads certified engineers and ring them all up to discuss your issue and the best price...
i called up about 6 engineers whose numbers i got from vicroads and the cheapest i found was $660
If you can find cheaper please point me in the right direction.
What does it exactly say on the canary notice and fine u got?
Does it say full roadworthy needed?
I would be checking exactly what they wrote you up for coz he might have said u need an engineers report for your parcel shelf but didnt write it officially down. Wouldnt want to go wasting your $$ on something you dont need. You should get the parcel shelf fixed properly but may not need to pay an engineer to look at it for 10 mins and charge you alot of $$. They charge so much for their signature because if you are in an accident and they investigate and find the item they signed off for was faulty they will get reamed, so they are just covering their asses.
I was told a bunch of crap when i got done years ago but all they wrote was I needed a full roadworth. When the roadworthy was done they didnt worry about any of the crap i was verbally told, and when you hand in the paperwork at vicroads they couldnt care less either.
i got done for:
Ground Clearance - my cars to low.. fair enough :)
Tyres (2) - they are 89v or something when they need to be 90v or above, load rating or something?
Tyres (1) - front drivers side had a bald strip along the inside of my tyre cause car needs to be aligned which is fair enough
Structural changes (parcel tray) - VASS certificate to be supplied
Front End alignment - to be realigned
*plus i have a condition written down than i'm not allowed to drive in the wet until i change my tyres. which is also fair enough.
so its gonna be very pricey :D
some years ago(actually longtime ago) i had my datsun engineered by a workshop in carumm downs...think they were called 'Protek'...
they were the cheapest back then and were a nice bunch of guys, but i am not sure if they are still supplying reports...see if they are on the list.
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
