1993 Nissan Skyline GTS4
Approx. 92,000kms
2 door coupe
AWD
Turbo
Black
Engine
• 3” Turbo back stainless exhaust system
o X-force front/dump
o X-force high flow cat
o X-force mufflers
o Custom stainless piping
• Hybrid front mount intercooler
• K&N air filter with CAI
• Nismo oil cap
• Greddy/Trust radiator cap
• Cleaned injectors
• New plugs
• Detailed engine bay
o Polished plenum
o Polished cooler pipes
o Powder coated rocker cover
o Power coated strut brace ends
o Powder coated cooler pipes
o Blue silicon hosing
Suspension/Wheels/Brakes
• HKS Hiper Damper coilovers (adjustable height/dampness)
• ARC adjustable castor rods
• Poly urethane upper control arm bushes
• Front & rear strut braces
• 17x8 AVS Model 5 white
• 17x9 AVS Model 5 white
• BFGoodrich G-Force Sport 235/45R17 tyres
• Type M brakes (4pot fronts, 2 pot rears)
• Bendix Ultimate front pads
• Bendix Advance rear pads
Interior
• Apexi pen style turbo timer
• DRFT boost & oil pressure gauges mounted below stereo
• Type M leather steering wheel
Exterior
• Clear corner indicators
• Type M grill
• Rear spoiler removed
• Tinted windows
Stereo
• Eclipse CD/MP3 headunit
• Audiobahn 6x4” splits
• Clarion 6.5” splits
• Alpine 5 channel amp
Car is very clean and very straight, interior is in excellent condition with all working vents
Am after $15,500 with RWC
Many extras available such as spare turbo, stock intercooler, spoiler etc.
https://www.sau.com.au/forums/topic/78601-fs-93-r32-gts4/
  • 4 months later...
heh good luck with the sale matt :P
been in the car, absolutely immaculate and clean all through.
handles well too :P
Edited by Angelus
https://www.sau.com.au/forums/topic/78601-fs-93-r32-gts4/#findComment-1740186
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
