Posting for a mate, call Phil for more details/prices - 0419 927 654
He will give good prices, has been in an accident so call for panels/windows etc
Ill update thread when i know more about prices but theres no harm in calling asking for price hes a good bloke.
Parts from a black R33 Gtst, ALL interior etc
- RB25 gearbox ~ $1000
- Rb25 turbo SOLD
- 3" down pipe off turbo $200
- Diff with 4.11 ratio $800 FIRM
- looks like R33 GTR style rear wing SOLD
Misc parts
- 17" ADVANTI Racing rims in black with tyres $800 FIRM
- Front mount cooler ~600x80 thick $300
- 3" HKS exhaust $200 FIRM
- Blitz BOV $300
- Bleed valve
- HKS black faced EL boost guage $150
Stereo
- Alpine CD-9823 (fr & rear preouts) $200 FIRM
- Alpine type R splits SOLD
- 15" Rockford Fosgate PUNCH sub in box
- 2 x Alpine V12 Amps SOLD
They are not my parts so please call/sms Phil - 0419 927 654
CD only
Detachable face
CD changer controls
18 watts RMS x 4
Front/Rear preamp outputs
MOSFET internal amplifier
18 Radio presets (12 FM/6 AM)
Bass Engine
BBE processing
CD-Rs, and CD-RWs compatible
MaxTune tuner
clock
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
