  • Replies 63
HEY! finally a thread bout cs!!!:mad:
my name on the servers is 'DTHNDK'
i play in the internet cafe's
usually on fridays from 1pm til 4pm cos thats my day off from uni
sum pointers to use when playing cs source
"change ur mouse sensitivity!!! i set mine to 2.9 very effective;)"
"aim UP! headshots wins the day! and saves ur arse!"
"stick in teams, dont stray!"
"flashbangs are the best anti-camper weapons EVER"
"smoke grenade urself, to give u cover, NOT ur enemies!"
"use radio commands to ur advantage!"
"use ur headset speaker to ur advantage as well! press K"
"mp5 has been improved dramatically in source, accurate and deals a bit more damage than in previous versions"
"five seven is the best pistol in the game...accurate and heavy damage...beats desert eagle in sum instances"
...thats all i can think of now:p
oh wait, hang on...i got some more pointers....
"believe it or not, but grenades are actually more important than ur guns! think about it, flash the guy, he cant see....no matter wat gun u got, he's dead already"
"stealth walk and pay attention to ambient noise, running footsteps is a telltale sign that some1 is coming...then look at radar! if there is no friendly dots there....ur close to an enemy! use that to ur advantage to ambush them"
"most guns are able to shoot bullets thru various things such as crates/ doors...remember that...ppl take cover behind those things, just pepper the crate/door...adding a frag grenade there might also get u that lucky kill ;)"
cs days.. I tried so hard last year or the year before, hell I can't even remember was back in the 1.5 days before steam anyways. I practiced on bots and everything and I got owned time after time after time mainly because of the shithouse 56k connection I had with a ping 400 or so might explain the problem, can't wait for BB.
For those who play now is CS really bad for download limits? because I would love to get back into it ;)
i dont think its too bad - If I play all night (for about 6hrs or something) Ill probably chew up 50mb i think? sometimes less
probably even less than that.
u online 2morrow night coxy? can't play 2night cause i'm downloading dvd's atmo.
Guest Mashrock
i have [bNR32] after my name if your ever on there.
i am on ever day/night pretty much its fun!
often get accused of cheating. but its all lies i just rush in and rape the other team. they love it.
i'm usually on the gamearena, optus, and gamespace servers!
come kill me!
Guest Mashrock
this i find so important
no use using a whole round on nothing.
thats what the para is for!! **** i am so inlove with that gun when i can afford it.
i can take out the whole team if all the ****ers go the same way.
i will post up what server i go into tonite when i get home.
should be about 10-11ish.
hey man! yeah ill be on for a while... is there a way to search for someones username to find out what server they are on, etc. without having to jump on to it?
come kill me!
:chairshot
hehe
yeah when checking the steam servers i'm pretty sure there is a way to check who is online, i think possibly right click on server cause i know it does give you some options.
i definatly know that when a server is full and you are que'd to get on, you can see who is playing.
cool ill keep an eye out - and ill see if I can keep an eye on this thread too in case we cant find anyone : )
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
