then its got me mc****d what turbo i actually have then .. if its not a rb20 one ..and it doesnt have the markings of a RB25 and its not VG30 turbo of a 300zx..... what in the hell is it off? ..... if anyone can confirm it for me.. id appreciate it ....greatly
matt
  • Replies 316
Posted Images
Ah shit.
Oh well, I will most likely get them turbo from zoom, as GCG has confirmed it's the right one.
Then it seems that there is NO difference in casting marks or identification between the turbos.
Shite
So reasonably comparable for new, and a bit more than used. Sounds good, comes with warranty so a decent option for those interested.
Ian, I think you are right, but find 220rwkw was too much on stockish suspension so the lod R33 needs plenty to tie the thing down. 280 would be tyre murder :(
Hi Geoff, I've spent more money on suspension than the engine...LOL...Whiteline everything they make for R33 and Bilstein, Strut Braces Front and Rear, Adjustable Caster Rods, Adjustable Upper Rear Camber Rods. And Brakes have been hugely upgraded....Ohh and one of your magnificent Hicas Lock Bars.
Ian
Just to throw another spaniard in the works , there is another exhaust housing by Garrett thats 1.06AAR and twin entry T3 flanged for the TA34 turbos that could work . It has no waste gate so not a straight fit but may work for some .
Cheers A .
So here's what I can figure out.
Stay with me.
RB25DET turbo
OP6 on exh housing
45V3 or 45V1 (series 1 and series 2 or R34 GTT turbos)
RB20DET turbo
OP6 on exh housing
16V on comp cover
VG30DET turbo
OP6 OR V45 on exh housing
16V on com cover.
So, there ya go.
i see what u mean by the exhaust inlet side ..distance.... but can i safely say that its not a RB20 turbo?
Matt
It looks like a rb25 compressor and cover with a VG20 exhaust wheel and exhaust housing.
it is BB. you have an unusual turbo there:)
If its a RB25/VG20 combo it will put out about 215rwkw on an rb20. its exactly what i had on my rb20.
hope that helps.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
