Does anyone know the backlight colours on these items:
- Nismo's white face 320km speedo cluster
- Trust white face boost gauge
I know Apexi Boost Gauge has blu-ish backlight colour, so if Nismo speedo has the same blu-ish backlight colour, then it will match Apexi perfectly. Not sure about Trust boost gauge.
https://www.sau.com.au/forums/topic/7905-nismo-white-speedo-backlit-colour/
thx nissaner...
so trust boost gauge is definitely DOES NOT have blue backlighting, right?
Cause I wanna match the colour white face when it's off (daylight) and the colour of backlighting when it's on (night time)
they match ok in daytime but not at night Apexi whole face lights up pale blue nismos face is dark at night with only the numbers and logo + pointer and a fuzzy ring around centre lighting up . Nizmo looks good at night and I don't mind the mismatced Boost gauge 'cos it's off side in a pillar mount
http://members.optushome.com.au/jay51/our%...5-32/Instru.JPG
I'm sure you can replace the bulb that illuminates the speedo, etc.
How difficult is it to change actually? I don't mind the standard look dials, but they could do with a more interesting light colour.
I can solder in something else easily enough.
Originally posted by R33-JET
nismo dash is sexy at day and all
but at night it lacks to light up all that good
sometimes u cant even make out the numbers
only my opinion
also have new apexi electrical gauges that light up mad blue
which look crazy at night
First, I won't be doing much night driving, mostly day only.
So white face nismo will look great at daytime when I do my driving most.
Secondly, the nismo speedo lights up in greenish backlit, so I won't buy Apexi boost gauge coz I don't want one thing light up in blue and don't match up with others. So I will go with Trust white face boost gauge, which has the similar colour with Nismo backlit at night. I'm sure someone mentioned this in other thread I can't seem to find which one again.
Anyway, my car's wine red so theme-wise I don't feel it will match well with apexi's glowing blue lights at night... so my choice are fix: Nismo speedo & Trust gauge combination... thx everyone for the input.
Hey Jay...
Does your Nismo speedo cluster comes with all the warning lights like ABS, HICAS,etc? Since it is meant to be for a GT-R, if installed on a GTS-t, will the ATESSA (4 WD system) warning light comes on????
RS73 - I wanted to match my nismo white faced gauges to a boost gauge so I got the Trust one and yes they match.... almost identical. Have a look...
only my opinion
Not to be rude but I think that the nismo dash is crystal clear at night and better than the standard gauges. ALso if you look at the pictures above even in the VERY BLURRED background image of the dash I can make out the numbers. I've had the nismo ones in pretty soon after I got the car and they are clearer than almost any other car. Like RS73 I didn't want green gauges and blue light cos it looks like a circus.
As far as I know all nismo dashes for the R33 GTR are the same except for the white/black combos. And no the warning light does not come on because I believe its for the Active LSD (correct me if I'm wrong) which is only for the Vspec GTR.
thx 400hp, I've been lookin for that pic somewhere.
I can't think where you put your boost gauge....
pillar mount should be on the right, or you mount it somewhere to the left of the steering wheel?
Or your car is left hand drive?
Nah my car is right hand drive... I'm in Sydney dude :P
The boost gauge is mounted on the steering column covering part of the speedo. I don't really care as it only covers 220km/hr - 320 which you won't see often in Australia anyway... I thought about it heaps where i was gona mount it. I didn't wanna get defected for the A-pillar and didn't want to drill. Anyway I'm happy with it.,
u have to pull out the whole dash console to get to the bulbs!
rs73
if u want the apexi boost gauge to match your dash get the EL dash kit like mine.
INASNT,
I'm after the 320km/h speedo from Nismo, which has greenish colour backlight (the numbers only). So Apexi EL gauge is out of the question, and I am going with Trust gauge as the backlight colours match the Nismo speedo nicely as shown by 400HP's picture above....
Originally posted by rs73
INASNT,
and where exactly are you planning on doin 320km/h?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
