hi all,
this thread was originally started by me to fix a fuel problem i had, which later turned out to be a dead clutch.
this thread has since been going on for some time with mainly DIY self tuning comments and pointers.
theres quiet a lot of useful stuff in here, you should read it from start to finish if you are interested.
i have a posted a few various maps in the threads, feel free to use the data if you wish.
be wary of just blanket loading my maps as it your car may go bang or lean out too much etc.
thanks
If you've fitted a new pump and now getting a flat spot it will be due to it running too rich.
Drop the ign. timing back to where it was and pull some fuel out of that area.
Be carefull though.
Unfortunately you will never know exactly how much fuel to pull, looks like its dyno time again. :)
Be carefull, those rb25det ring lands are fragile. :)
hey thanks for reply
well i tried +4 deg and 1.101 inj correction this monrning and it ran great more zest everywhere and a tiny bit of knock but still that ood spot at 2800ish. i now get clutch burnt smell almost all the time and it seems more and more likely my clutch is slipping. last night after 15mintues of hard work it slipped from 4500 to about 6500 in 4th under full load. today it was fine but that very minor slip or flat/wierd spot at 2800. is it likely to be clutch and just a concidence at that same time i did the fuel pump ? also my fuel economy is out the window. off the charts. 200 to 3/4 of tank. ill be lucky to get 250 to a full tank. previously before the pump 330 easily most of the time
The only way changing fuel pumps makes a difference to A/F raios is when the previous pump was not holding pressure. The tuning was done to allow for this drop in pressure, now there is no drop in pressure, so the tuning is rich. If the igntion timing (maps) were right on the old pump, they will be right on the new pump, just the A/F ratios need to be retuned.
Clutch slip during boost build (rpm) is very common, time for a new clutch, drive gently until then othwise it WILL let you down.
thanks for the help guys. im not sure on the a/f or how it was tuned previously other than the dyno graph ive got. any ideas why my fuel economy is off the scale now? is it because its mega rich now. i know the previous pump was maxing out or pretty close too as they said it was leaning out when they did a test tune at 0.90bar (dont run that normally).
should i try a drive with 0deg ing and -0.900 inj correction to lean it out a bit and see if it doesnt knock around too much. if this -0.900 inj is OK and not knocking too much then its most likely they tuned around the pump but not since a new pump is in i need to lean it out a bit? will have a think about the clutch and what my costs are, may just back the boost off a bit for a while
will do some hunting around on some clutches and see what i can find. definetly getting clutch burn smell. turned boost controller of so im at 0.45 bar and its fine no slipping so its driveable and not the end of the world but still an issue. is there a relatively easy/cheap way of getting my fuel economy back? maybe ive screwed up the level float for the fuel tank somehow and its not really 1/4 left but more like half or something? who knows. thanks for help guys
hey guys
back to the self tuning point, the point of this post anyway. im going to get my clutch issues sorted out. but in regards to my comments:
"should i try a drive with 0deg ing correction and -0.900 inj correction to lean it out a bit and see if it doesnt knock around too much. if this -0.900 inj is OK and not knocking..".
I am trying to make the tuning of my car easier for when i take it to get done so that the tuner doesnt just go dyno run yep its ok doesnt knock sweet all done. $200 thanks.
I tried +4 deg correction and it was knocking. adding more inj correction and knocking dropped to normal levels. The tuner would obviously benefit from knowing this as they can immediately crank all ign maps up 4 for each value. now would it be wise for me to do this at home and change each value before the dyno run and just run on a little inj correction to keep it from knocking until tuner sorts out the rest. this is so i dont get charged for the tuner to go through every single ign value in the ign map. i also suspect the tuners im going to arent actually doing hardly any map changes and only making minor changes to ones the map tracers hits on a 4th gear run
what are other people experiecnes with pfc tunes? have you actaully watched your tuner go through and edit every value? is it really needed?
not trying to be a smart ass or anything just trying to get the best use out of the powerfc, learn a bit, maybe do up some documentation and get some more power / have some fun. it would be great to goto my tuner and go my car runs sweet on +xyz deg ign and +xyz inj correction make it so and make sure it doesnt go bang or do whatever to make sure its safe
once ive got it all sorted ill get a mod to remove all the crap regarding my clutch and fuel pump as they are irrelevant to the initial topic. thanks again
I tuned my car myself on a mates dyno. It certainly a slow process. We tuned it at light throttle, zero boost then at full boost at all rpm levels monitoring this by the map trace. Increments of 400rpm made this a slow process. During this we altered A/F ratio levels. I noticed we didnt really alter the timing levels just making sure there where no funny movements on the ignition map. As load increases , timing is pulled out which should be in factory tune. A/F ratios where very rich so we picked up alot there. Overall its a great experience and now i fully understand the functions of the power fc in my car.
Experiment with it, but you really need a dyno to see what A/F ratios are. It took us at least 3 hours.
Tuning with a PFC pretty easy, the base maps are not too far from the right shape. All up the R32GTST took about 40 minutes to tune. My method for A/F ratio tuning;
1. Do a power run with zero correction, took about 8 seconds.
2. Closely look at the A/F ratios from that power run. Took about 3 minutes
3. Pick a range where the A/F ratios were fairly constant but very crappy, which in my case was 4,000 to 4,500 rpm where they were just under 10 to 1.
4. Do another run and used the dyno load to hold it in that rpm range and apply correction until the A/F ratios were between 11.8 and 12.0 to 1. Make sure there is no pre-ignition with those corrections. Took about 15 seconds.
5. Make careful note of that correction, about 5 points made 1.5 A/F ratio diff. Then make guesses for the other load points following the A/F ratios from the first power run. Took about 10 minutes.
6. Do a power run, and tidy up the A/F ratios as required. Took about 40 seconds.
7. Finished.
The real trick is #5, noting how much correction does what to the A/F ratios and where the various load points are on the map. That reduces the time under load on the dyno and it is very fast loading up corrections off line. Doing it in during a power run is tricky and much slower, plus it heats up the engine rather quickly and is not good for the transmission (no 160 kph airflow to cool it down).
Ignition timing is even easier, stick the ears on and advance it up until you hear it ping then back it off. Do that at around 5 or 6 load points, then (off line) extrapolate that over the map. It's always a bit tricky at boost building time, so we have to spend a few minutes in that area getting the timing just right.
One power run to log everything and then maybe a little tidy up here or there. That's the real advantage of a PFC, the base stuff is already there, so you don't have to approach it like EVERYTHING needs changing.
Most of the tuning on the race team cars is done by our dyno guy, he has a "feel" for it. What takes me 10 minutes to get 99% right, he does in 2 and gets it 100% right. :fart:
Hope that helps
cheers guys, owe you all many thanks for feedback. will get my dump fitted and clutch sorted and see where im at and hopefully get this tune cranked up. is it normal to be able to throw in 4+ deg and some fuel and the car run fairly well. i noticed more power and zest but had to add some fuel cos it was knocking. will update next week some time
um i recall seeing around 15 odd at full stick, when i threw in +4 it was around 19deg and i had a nice power increase. does this make sense? i can do a test tomorrow at say 5k in 4th and check what ign deg it is
What boost? 19degree's sounds a little high for the 9:1 RB25DET. :(
The stock base map pretty much always makes the rb25det ping, generally timing is pulled out.
I'm running 16degree's any more and it will start to ping. Bl4ck32 has a highflowed turbo that free's up the exhaust and is able to run a maximum of 18degree's up top with around 17degree's everywhere else from memory.
Its too hard. ;) Get it on the dyno for a cheap power run to see whats going on.
Make yourselves some Excel charts with all your settings. Takes about 30 mins.
It gives you a full picture to examine when you're doing road tuning, not that little screen.
Do a before and after set from your dyno tune and list your mods so you can e-mail to others.
Regards.
yeah i definetly will be doing that. shame i dont have the datalogit or fc pro cos then i could just suck down the maps. does anyone have stock rb25det powerfc map on file? i wanna compare it to mine to see whats been changed so far and see what a "tune" is.
cold: 25deg idle. under ign correction normal value is 15 with 0deg correction. if i throw in +4 deg correction final ign goes to 19deg.
normal temp: 15,16, 17 deg idle it hovers around those. on full wot ign timing goes to 19deg
  • 4 weeks later...
the current tune is awesome and runs well. ok here is a map trace of my current tune. this is all done on light load and not going much over 0 vacumm. i spend the majority of my time accessing those cells highlighted. my fuel economy is currently around 320kms for a full tank. id like to get some more fuel economy so im going to load my tune into fc pro and fc tune and look at the cells that are being hit by the below map trace and then look at leaning them out a bit. question is how much should i adjust the value? if i do it too much what signs would i see ? smoke? knocking? noises? any advice would be great as i would like to lean it out on those cells and get some better economy but dont want to risk the engine etc.
http://members.dodo.com.au/paul/pics/paulr...e-lightload.jpg]http://members.dodo.com.au/paul/pics/paulr-maptrace-lightload.jpg
more on sunday or monday when i load in my tune and then do some testing
320 on light throttle is attrocious. Did they just tune your car for full throttle and not light throttle?? A/F ratios are much different at light throttle. We tuned at very light throttle then zero vacuum and then full throttle. The factory PC maps is quite rich at light throttle.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
