Busselton
  • Replies 60
ur mates mates mate test drove the car and saw what he was getting when he handed it all over :)
the seat (single) and mags came off ages ago. well before ya mate had interest in the car. as for the CAI it was just some flex pipe, $10 from bunnings :)
trust me yer mate got a VERY good car which should have sold for a lot more then it did :)
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-116910
I was cruising back from Margeret rvr just after x-mas and i waved to an R32... i got a thunder grey r33..
Also as i arrived in margs on x-mas morning there was a white r33 on the lawn of some house. at the bottem end of town. didn't see it again tho'.
i know whatyou mean about ppl down south noticing the skylines. heaps cool :D
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-118423
Originally posted by Pva_Glue
4 skylines
2 silvia
2 180sx
2 EAX
around 20 -25 people...
cheers
Joe
Hey, did u forget about me in my abscence eh:(
that was a nice drive but i think it would be a little harsh driving to and from in the same day (6hrs on the open road) would be better to make a weekend of it again.
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-119181
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
