My late Chrisie Presie
Originally posted by skyline33
800 thats alright, do you mind me asking where from
importer in st albans!
He had a shit load of apexi and other 1'c 2, but they were sold and this hks and a bigger 850x400x96 was the only 1'c he had left till he gets more stuff in about 4 weeks!
And its brand spanking new!!!
He had all the ceramic coated piping available but was a bit expensive!!
$800 sounds pretty damn cheap!
The one I'm looking at isn't quite as big (600x276x76 I think) but comes with the full piping and pretty much everything I'll need. Its a Trust V-SPL. Should be able to get it on the car for around $1200-$1300... does that sound reasonable to anyone?? I thought it was considering that UAS want more than $2K HKS coola... plus installation!!
UAS mark up their stuff 200%!!
what type of piping is it? the ceramic coated stuff is the best stays really cool and flows the air really well!
Dunno I think its just aluminium. Can you get them coated??
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
