Why do automatic tranny cooler lines run through the radiator?
Thats the question.
Do only autos come with the radiator that ducts them in?
Can i bypass it and run just a front mount AT oil cooler or does it assist in the cooling or oil thining/thickening?
Cheers
Thats the question.
It's an oil cooler and generally all auto cars have one in the radiator. Yes you can run a separate trans oil cooler - it actually extends the life of the tranny esp if you plan on engine power boosts.
I know its an oil cooler the point of the question is why is it ducted into the radiator
and what ramifications will it have if not used but just running a big tranny oil cooler
Cheers
Cheers
It's cheaper to do it that way in mass production, plus it allows the tranny fluid to reach operating temp quicker which aids driveability. I've also read somewhere of one manufacturer (toyota from memory) claiming that it reduced emissions by optimising operating temps, etc.
It is almost invariably better to disconnect the factory cooler and run a separate air/oil trans cooler. The factory type is small and you can usually fit a larger aftermarket type that gives better cooling all round and will extend trans life. For a standard car the factory cooler will do the job, but boosting engine power or continuous engine load (eg towing) makes fitting an aftermarket cooler mandatory AFAIC.
Downsides - finding the space + the trans will take longer to reach operating temp esp in cold climates (eg winter in melbourne)
I know for a fact there are atleast 2 different radiators for r32s. One is an auto one, with the trans cooler part, one is a manual one without it. Obviously I'm not 100% if *all* auto ones got the auto radiator or if *all* manual ones got the manual radiator but it would stand to reason.
I would probably keep the transfluid running in to the radiator then in to the external trans cooler then back to the gearbox.
Setup that way would no doubt help absorb peak hour traffic trans fluid temps when there is no air passing through the external trans cooler.
when i fitted a trannie cooler to my R32 auto, i found that it did indeed have the factory AT oil cooler on the bottom of the radiator...
i simply run the fluid through this cooler, then through my aftermarket cooler, then back to the trannie :rofl:
How would running the AT cooler lines through the radiator assist in keeping the fluid cool?
Granted it getsit to operatin temp quicker but is this one of those things that pulls both ways?
I will be replacing my radiator with a manual one so i wont be running through the radiator but will the setup be okay still?
You don't want your fluid too cold, it doesn't behave properly. They make these fluids to behave in a certain way in a certain temperature range. Outside the range and they don't work properly. I run mine through both the radiator and the cooler in the front drivers side air dam.
The liquid (transmission fluid) to liguid (water in radiator) cooler is the most efficient. Liquid (transmission fluid) to air transmission cooler is not as efficient, so it has to be larger. The Stagea (have a look at the transmission cooler thread in the Stagea section) has both standard, I simply replaced the small standard air to fluid cooler with a much larger and more efficient Davies Crag transmisson cooler. But I kept the fluid to fluid cooler as well, can't have too much transmission cooling when towing.
As long as you use a large enough air to fluid transmssion cooler, then you can live without the fluid to fluid cooler. Make sure you put it in the line of airflow from the radiator fan, that will helpo when in traffic, not moving much for long periods.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
