anyone ever heard of one/know where to pick up one???
trying to remove crank pulley bolt,
i tried wedging a screw driver into the teeth of the fly wheel ringgear
whilst trying to undo the pulley bolt but that was kinda dodgy and didnt work....
anyone know any other ways of removing the bolt without the ringgear stopper?
i also tried just putting the car in gear but that also didn't work...
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/
Put an impact socket on a strong, long, breaker bar. wedge the end of the bar on a chassis rail or something really solid. Disconnect the coil loom or otherwise stop the engine being able to start. Flick the starter key for a fraction of a second. The starters power and the engines inertia wil jar the bolt free. be careful, if something slips or breks metal can go flying with serious force, don't have anyone standing overlooking the engine bay!. A bit crude, but very effective and a commonly used practice. Nicer way? Air gun on the pulley bolt.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458141
I undid mine not long ago, i bent a few ratchets in the process and a rattle gun wouldnt budge it.
I purchaced a strong/long socket bar from repco and a THICK long pole on the end of that and even then it took me a shit load of back and forth tugs before it snapped loose. I couldnt believe how tight it was!
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458144
Driver: I undid mine not long ago, i bent a few ratchets in the process and a rattle gun wouldnt budge it.
Yeah but how did you lock up the ring gear on the flywheel to enable you to stop any rotation of the pulley??
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458165
I managed to do it with the 2-screwdriver trick. The screwdrivers need to be reasonably substantial, and you need a long breaker bar on the bolt. This was with the engine out of the car, though. Also helps to have a helper.
I've also done it with the engine installed (to replace the water pump). Pretty sure I just stuck it in gear, and used a 18" breaker.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1459043
Put it in gear and pull the handbrake up very hard , if you have a helper get them to put their foot on the brake .
If you have a gtr you will need a 3/4 drive 30 mm socket and a srong bar , for a gts 27 mm socket .
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1459061
Yeah i tried that but even with sumone pressing the brake the car was moving...My clutch is on the way out (slips during launches more than 3500) Could that be the problem? I guess it cant really be cuz the car still moves. The brakes just dont seem to bight enough without any booster.. Im thinking to just re install the starter and do wat Chris Wilson posted...Any more tips?
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1460262
Still no luck with the crank pulley bolt. ive tried putting a screwdriver in the ring gear teeth and it wont hold it enough. Just slips and sparks. So i tried putting th starter back in and using a breaker bar jammed up against teh chassis rail while i flicked the starter over for a second. That also didnt seem to have enough power to undo it. I tried that alot of times but was worried it would burn out the motor... I need HELP!!
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1462073
The starter will work if you have a fully charged battery and dont jam the bar on the rail , leave the bar some slack and put a block of wood on the rail so the bar hits the wood and not the rail . Hit the starter and if it doesn't undo don't hold the starter on , let go and try again but this time give it more slack , 2 or 3 goes and it will come . Make sure the bar will hit the wood only otherwise you will damage whatever it hits and don't stand in the way .
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1462753
Hi Deren, I replaced my 32 GTR timing belt a couple of months ago and had a god awful time getting the crank pulley bolt off. The "breaker bar on chassis rail and crank the starter" method does not work on RB26's as the bolt is torqued too tight - it works OK on 25's and 20's as their bolt has half the torque of the '26.
This is how I got mine undone:
1. Car in 4th gear, hand brake on as hard as possible, helper in drivers seat with foot as hard as possible on brake.
2. Breaker bar on crank bolt with long pipe (1.2metres) on breaker bar handle.
3. Put as much pressure as you can on the end of the pipe with one hand and hit the pipe with a decent sledgehammer with the other hand. You really need to put a lot of pressure on the pipe before you hit it or it won't work.
4. 3 hits and my bolt finally came loose and no damage was done - have driven 5000k's since timing belt replacement with no problems.
I know it sounds agricultural but after 6 hours trying to get that bastard bolt undone I would have tried anything!
Hope this helps.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1464288
I saw a mechanic having a bad day one day and in his haste he held the bar up to the wrong side of the chassis rail....
Ended up with a broken pair of glasses and a busted nose..... It sort of went like this "watch how we do this you apprentices... *whack* - You *ucken mole"
Sumo
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1464440
Managed to do two within half an hour when changing the pulley arrangement over from my R33 engine to my R34 engine. Both out of the car, both jammed with a screwdriver.
What you need to do is apply a shock force as Marriott said. Applying a steady increasing force won't do the trick. Get an 18" bar and a gimpy/copper hammer and belt it a few times.
Here's a question, are you actually trying it anticlockwise or clockwise?
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1465470
Hope this helps.
That deffinetly did help! Thanks heaps worked a treat! I really didnt think id get it undone but you saved the day for me. Thanks mate!
Deren
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1466297
Now that Deren has the bolt off. How do we go about putting the bolt back on?
My workshop manual specifies the torque specs on the balancer bolt as 329-344 ft/lb or 446-466 N/m.
I have a huge 3/4" torque wrench with an 1¼" (approx 30mm) and with the car in gear the brakes hard on I can't put adequate force against it.. the driveline has too much slack and the car rolls slightly.
Whats the solution?? I'm thinking rattle gun at this point, even though I don't like the idea.
Cheers.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1466557
Deren, glad you got it off.
I used the same method in reverse to do the bolt back up. Its such a large bolt with fine threads that there is no chance of stripping it, so I did it up as hard as I could with the breaker & extension and then whacked it a few times. Hasn't come undone so far.
Cheers.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1469703
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
