Chris,
How was the O2's response (0.2-0.8v cycle speed) affected with the change ON IDLE? If the lag time is out the closed loop function finds it hard to cycle quickly.
Edited by Cubes
Didn't check that as yet mate, will have a look tonight
Economy has been quite poor for a while now, hope its a bit better now
Edited by Chris32
i've been running my car with closed loop disable for about a month now and i'm getting 300-350km per tank with city driving only. I find when i enable closed loop my idle becomes jumpy. Possibly stuffed o2 sensor
Chris,
Checked this on the way to work today, response was very quick
Never checked it before though
Economy seems to be a bit better too
  • 1 month later...
Mine is still giving me the shits
Playing around with injector correction % on each injector now. Last night I went through each injector and added 2% more fuel to see if it would help with my random knock
Injector 4 showed the most improvement, knock going from 80 to 24 at 1.3bar
so now my injector correction reads
1 59.5%
2 58.5%
3 58.5%
4 60.5%
5 59.0%
6 59.5%
Maybe I am finally onto what my problem is?
Worst knock I saw on the way to work this morning was 33. It used to be up in the 70's
Running SAFF 98 with 10% ethanol. The fuel itself showed normal knock numbers compared to BP98 before I did the adjustments
Edited by Chris32
The car feels and sounds allot better. Maybe its just me, but the exhaust sounds crisper than before
The injectors were cleaned and tested a year ago, and where all within 1% of eachother. There was one which was a bit clogged, but it all was ok
Will see how it goes in the next few days
If only we could tell which knock sensor reads what. :P
Chris, If it is indeed pinging slightly and has been for some time then those little rb20's are tough little nuggets to crack.
Edited by Cubes
I've done that mod.. it doesn't appear to make any difference to how the bov opens or when it opens.
I did find drivability to suffer a little when cruising around the hills. Made the car jerk around more when you jump off and on part throttle. Depending it may also increase the chances surge.
So.. I removed the grub.
Edited by Cubes
If only we could tell which knock sensor reads what. :)
Yeah, I think it probably is detonation, how much is hard to gather
Been like that for over a year now, close to 18,000kms!
Will keep going in the process of elimination to see what differance more of a play with the injectors does
BOV mod works well on mine, does make on off throttle driving a little harder to keep smooth
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
