I had to collect all my own. The ones I couldn't find I had to retrace. I have quite a collection going now of about 140-150 logos. If you're a member on the SilviaWA forums, I have a list of them there in the Traders section.
Cheers
Brendan
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1464287
Cheers
Brendan
Brendan is awsome, he did 3 stickers for me, 2 custom and 1 tomei sticker; and what can i say they came out awsome, really top work, price was good too :)
p.s im evl_r33, you did those tuning house stickers for me (i will contact you soon on again, as i need another 3 or 4 for some friends :))
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1464342
Thanks mate, and if you haven't gathered from the above post, I have a vinyl cutter. I'm mainly only doing logos and stuff as I'm not quite setup for doing racing stripes et al. I did however do the graphics on 'Angry13' which some of you may have seen at the recent Cabin Autosalon under the SilviaWA banner. Also did all the ones on the C-Red cars except for the racing stripes (S15) and window tinting (JZ, S14).
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1464389
It really depends on what you want to do. I mean with Woody's car (Angry13) I already had vector art laid out on an outline of a Silvia already done. So I resized to correct size, cut and applied. I applied dry though, not wet which can also be done.
In regards to taking off, it depends on whether or not the paint has had time to cure. Woody's paint is original, so there's no problem. But with new paint you need to leave at least 2 weeks before you apply graphics otherwise when you pull it off you can take paint off. When you're taking it off, either leave in sun for a while or use something like a heat gun to make it easier to remove. If there anything left over (glue/gum), first use some mineral turpentine on a rag and soak the area, if a lost of glue, soak and scrap off with a plastic card, then use methylated spirits to clean off. Finally before applying any graphics use IPA (isopropyl alchohol) to clean the area. If you apply graphics onto newly polished areas, don't expect it to last as it doesn't stick well and the polish and any other contaminents can gas out through the vinyl sticker.
Here endeth the lesson.
Cheers
Brendan
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1464877
Hehehe, well there's differences firstly in the way the vinyl is made. Some is sort of stretched out (calendered) and the other is layed out (cast). Cast is the better of the two as it doesn't have the inherent tendency to want to go back to original shape. It also depends on the manufacturers specifications, the longer you want it to last, the more you pay. The manufacturers will guarantee it to last a specific amount of time as long as it's been applied properly. It also depends on it's location on how long it will last - full sun facing up versus side of car, minimal sun. Hope that gives you an idea. I tend to use only the better stuff (Avery 900 series vinyl) as it's a little easier to work with most times and you never know how long it'll need to last. But I always give caveats to the customer depending on whether or not that polished the car recently etc etc.
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1467884
Computer images are viewed as one of two types (mostly) - raster or vector. Raster images are those wholly made up of pixels (coloured or monotone) - examples are photos (JPEG's, Bitmaps, TIFF's, RAW) and gif animations. When you zoom in on a raster image, all you'll see is bigger pixels. A vector image however is made up of how should I put it...mathmatical data for want of a better term. Basically is says to the viewing app draw a line from this point to that point in black and make it 0.25mm thick. Vector apps include Macromedia Freehand, Adobe Illustrator, Corel Draw, Macromedia Flash (which can use both vector and raster) and to some extent Adobe Photoshop (although that's a mainly raster based app). When you zoom in on vector images, the lines, colours, shapes and fills stay sharp even at 1600% magnification.
Hope that explains it.
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1468445
  • 6 months later...
just wondering what prograns u use to convert bitmap to vector. i use coral draw and vinyl master pro at times just wondered if you had found something more user friendly :angry: i have a vinyl cutter as well and have hundreds of stripe type graphics already in vector
cheers mid life crisis
https://www.sau.com.au/forums/topic/80318-vector-pictures/#findComment-1905681
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
