Hi all
just got a new job and new mobile Sony Ericsson K750i in the box and new pocket PC O2 XDA II mini
havind purchesed motorola's new phone couple of mths ago and allredy have pocket PC with everything in it these two are for sale...
Sony Ericsson K750i $500.00ono rrp $700.00-750.00
PC O2 XDA II mini $700.00ono rrp $1,199.00
mobile and PDA still in a box PDA not open and mobile open (to see it if its better then motorola) not used
PS these prices are just of ebay so if u can get them cheaper (don't think so) please let me know
PPS both are legit... from my printing company (boss would kill me hehe not)
THANKS & CHEERS
Pretty sure K750i has been released. My mate just got his gf one 2 days ago but that's Sydney not Perth.
thanks mate... not too sure about perth but as mini2 and i said crazy john is seling it for $829.00 here in sydney... on ebay k750i phone is going for around 600 bucks.
THANKS
thanks guys and sorry... im in melbourne, had to go re.work (unexpected)
will be back friday if all goes well.
once again sorry and if whoever is interested (with genuine offer) leaves me contact number will call them
THANKS & CHEERS
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
