hey jus did a few upgrades to my series 2 r33. time to sell the stock parts and a few others :O all are in excellent or good/average condition.
stock cooler & piping - $130 [sOLD]
stock dump pipe - $30 [sOLD]
stock air flow meter - $60
stock cat - $30
stock exhaust heat shields - $20
stock thermo fan - $30 [damaged: mounting bit snapped]
o2 sensor - $50 [sOLD]
GTR charcoal cannister filter - $80
GFB atomic boost controller - $40
apexi super intake air fitler - $50
3" jap front pipe (branded: bullet exhaust) - $100 [sOLD]
apexi hand commander 415-x001 - $300 [brand new]
i think ive got more stuff but ill add it in later. all prices exclude postage and pickup available if ur in sydney area :)
thanks
https://www.sau.com.au/forums/topic/80971-stock-series-2-stuff/
  • 1 year later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
