Originally posted by XCUZME
thaaaaaaaaaaaaat is soooooooooooooooooooooooo pathetic.
:talk2hand :talk2hand :talk2hand :talk2hand :talk2hand :talk2hand
pete what would u know about westside u pharmacy BITCH! :)
Sorry, coming from a Westside Wannabe who lives in Bondi but would much rather traverse the hood of Fairfield, your insults do nothing to me! HA!
btw, Northside? wtf is that || ??? Show me your Northside hand sign, yo!
https://www.sau.com.au/forums/topic/8098-teamwestside/#findComment-117994
For the //orthside symbol:
Right hand - give the finger
Left hand - the 2 finger salute
join both middle fingers at the top and voila! // :)
...as a bonus you are both giving the finger to and telling your recipient to **** off (...unless they are also //) :uh-huh:
https://www.sau.com.au/forums/topic/8098-teamwestside/#findComment-118007
