I just received a lewtter from the EPA saying that my car might not Blah blah blaH!!!!
i HAVE TO TAKE IT IN ON THE 19TH OF THIS MONTH so that they can test it.
What do they test for? And is it just for emission(better replace my decatted cat)????
My car isnt even loud so i dont think noise will be a proble.
Also will i have to change the fmic, bleed valve etc.
Thanx
https://www.sau.com.au/forums/topic/8104-epa/
anything over 90db is not legal for your car. i received a letter from them a couple of months ago, changed my muffler to a more quiet one, had it tested in d/nong, paid the $27.50 testing fee [f***in P**ks] and all was ok [was 87.5 db but was not a skyline, was a modded trx]. I think they tested for emissions too but noise is usually the reason for the letter - unless of course u are chugging out heaps of smoke at the back :confused:
https://www.sau.com.au/forums/topic/8104-epa/#findComment-117852
i think i might go get my zorst checked out... no way in hell its 90db its quiter than most aftermarket exhausts ive heard so far... but would be good to see what it is and that way i have something to prove it if anything pops up
https://www.sau.com.au/forums/topic/8104-epa/#findComment-117853
Guest INASNT
Thanx
if u got busted with the degutted cat u would have been down $5000 on fines!!
https://www.sau.com.au/forums/topic/8104-epa/#findComment-117972
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
