Squizz,
I have a set of forged pistons going in. They are 8.5:1 compression therefore doing away with the expense of a metal head gasket. If you planning on running boost over 1.2 bar then I think forgies are a good idea. The stock ones are fine below this, and with a larger turbo running 1bar you could still get 500hp from the factory pistons.
There is a form of heat treatment available for pistons, valves etc. but I decided to only bother with ceramic coating the exhaust manifold. Only if you were circuit racing would I both doing the pistons, cause in general forged piston need to be hot before they start to operate properly.
MIKGTR,
I'm pretty sure that the forged aluminum are lighter than the factory cast pistons, I was surprised when I picked one up and compared it to the factory one.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118092
SR20DET just means you need to buy 2 less pistons than me. I think the SR20 pistons are little bit better then the RB25 pistons I have, but as you found out high boost will kill them. I'd say go for it, but save the money on HPC the pistons and spend it on a better exhaust manifold, that is where most of your hp gains will come.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118101
Squizz,
That sounds like a great setup, and I'd definately suggest the forgies now, you don't want a weak point with an engine like that.
The plenum could be worth considering, I hated the design of the RB25DET plenum and the Greddy one is much better, I also have a 90mm throttle body to remove any air restriction.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118112
Squizz,
How much were you quoted for a set of forgies? You should be able to get a set of Wiseco pistons, with rings and gudgeon pins for about $1000. I would expect that the cost of coating your pistons would be heading up in this region.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118127
GTS-t V-SPEC: Yeah I spose talking piston weights is a bit "how longs a piece of string" they vary that much between each engine and each piston maker.
I was thinking CA18DET when I said it, doh, I didn't realise it was SR20....I went thru chasing up forgies for my CA18 and all the forgies I could afford (under $2000) were heavier than stock, the dearer forgies were light but expensive cause of all the machining to make them I guess.
As for piston coatings i'd be checking to see how long the coating is meant to last before it wears thru....I've used them before (not HPC) and found the coating worn thru after only a few 1000km. OK in a race engine but money down the drain in a street engine
Cheers
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118135
MIKGTR,
If your talking about Jap pistons then $2000 sounds about right, hence the reason I chose Wiseco. They are made from forged aluminum, very light, and are used in alot of race engines.
Sniffy,
The plenum is from Greddy, available from any decent import shop, cost around $1500, it makes the setup like that of a GTR, therefore improving the intercooler pipe design aswell. An Infiniti throttle body will fit on the end, if you can find one.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118138
available from any decent import shop...errr, i dont know any!An Infiniti throttle body will fit if i can find one...so im guessing they're hard to find. where do i look/go and how much is it going to sting my wallet?
how long would it take for a pro to install?
im guessing it would be easier if i got a FMIC to put on at the same time?
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118143
sorry for the thread jacking but....
GTS-t VSPEC:
Did you go direct to Wiseco or is there someone local that stocks them?? cause I'm building a CA18 at the moment and wouldn't mind chasing some forgies up again. Wiseco sure is damn good stuff!! I've used their bike pistons before but last time I chased up there catalogue they didn't have a listing for any Nissan pistons so I didnt look any further and all the others I tried - APEP, Arias, JE & Cosworth were close to $2000
cheers
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118166
MIKGTR,
Me and my mate ordered 5 set, 4 for SR20's and one for me (RB25), I think we got them directly from the distributor. I should be able to find out who on Monday and let you know. They definately do Nissan pistons now, with a whole range of compressions and sizes available.
Sniffy,
I just bought mine from Xspeed here in Perth, I'm sure if you ring around then you'll find someone who can get it in. It would be a good idea to do FMIC at the same time, save redoing intercooler piping. The Inifiti was hard to find, try your local wrecker, but they are eligible this year under the 15year rule, so there should be lots around soon. A 4.5L V8 from Nissan, sounds like something that needsa turbo.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8114-piston-question/#findComment-118181
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
