its nearly time to start modding the 33 so i thought id see if anyone could help me achieve the best results
im gonna be fitting a 3" exhaust from turbo back so i need ideas on places that do good exhaust fittings. im also interested in keeping it quiet to attract less attention without loosing any power (if possible)
i got a cooler goin on which is all sorted
and a safc2 which i will prolly leave in the glove box for the time being. ill probably get it tuned at chiptorque...
if anything else can be done to make more with stnd turbo and safc (like fuel pump. or reg or something) please tell
also, anyone got any experience installing a new stereo themselves using stnd speakers?
thanks for your time
https://www.sau.com.au/forums/topic/81162-plans/
As to the Exhaust, Rob Bliss did my dump pipe and I bought a aftermarket exhaust from japan that was 3" stainless and pretty much a straight system including 3" cat. Some really good prices landed are on offer if you are prepared to look and wait.
Dave
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1474967
i got my dump pipe through batmbl here on the forums
was excellent
chased up a secondhand gtr cooler cheap, which meant i could spend a bit more on converting the plennum to forward facing (less piping, less hassles)
got a good quiet blitz exhaust for less than 500 bux from option1 (they had plenty to choose from)
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1475126
Where you going to drive it mostly? Going to do any track or mountain work?
Sounds like you have the basics covered.. and should give you around 170-200rwkw with stock turbo. After that I would look at spending money on suspension, sway bars and other handling items before going too much faster as you'll be losing it to the ground. Sort them out and you can beat many other cars which much more power :)
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1475145
I Installed my own sterio I was thinking about using the stock speakers. However mine were buggered. The cones are paper and are either dead or about to be dead. I hooked my head unit up to the stock speakers and it sounded awful. Went to JB and got two sets of Pioneer 6' two ways for $98. Now it sounds 100% better with out costing too much. Ditch the stock speakers and look for some bargins on good brand speakers :uh-huh:
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1476226
Got in touch with vic member INASNT he can supply whiteline for cheaper than thier website.
Got to consider sizes now, thier upgrade is 24mm front & 20 rear but they also have 27F & 22R, he can supply the 27f but only 20r.
Is it worth putting that combo on or would it affect the dynamics as it is the rear I want to tame?
:confused:
Diam
Refers to the diameter in millimeters of the Whiteline/Selbys Swaybar catalogued bar. Generally these are "touring sizes" with replacements being around 1-5mmlarger than the original. Note that "extra heavy duty" oversize diameters are also available for many applications. Some Whiteline/Selbys Swaybars are of the same diameter as original, but only when replacing an OEMhollow or tubular design with a solid Whiteline/Selbys Swaybar.
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1478779
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
