i should be getting a coil from a GTS-t from one of the WA members a bit cheaper. provided the turbo coils are the same for the NA engines.
where can you get replacement springs or 'carbon rods' from? don't they attach inside the coil somehow?
u can get some replacement springs from a Nissan dealership. they just pull in and out off the carbon rod on the inside of the coil pack.
You can get springs from L & T venebles, there's one in Wangara. They're like $2 for a pack of 4.
I used them in my R32. You don't NEED the little carbon bit, it runs fine with just the spring.
and you just pop them in the end? they don't need to be stuck in there? :whatsthat
That will be for the carbon canister, usually located passenger side, just in front of the (standard) air box.
mm it comes out of there and over the engine but doesn't attach to anything else. even though it has a clip on the end as if it had been attached to something.
SECUR1TY: can't see any carbon rod in there either :D its all just white dust etc
i'll have to double check them tonight i think.
dont worry about the carbon rods.. my bad
just stretch your springs slightly and get a little dremil drill with a sander attachment and sand away the layer of shit on the inside of the coil where the spring sits in to a nice shine.
you'll be amazed on how much crap comes out of it.. all that crap causes misfires on everyones car because it doesnt allow for a good contact between the coil and the spring... and then they go out and spend $700 on splitfires.. this is definately a good fix for it. mine have been running excellent since i did it.
haven't had time to get hold of springs or a dremel yet but managed to get a coil pack which i put in last night.
was slightly different to my others and the plug didn't quite fit properly, managed to rejig it and connect it but it still sounds like a wrex :)
so i've pulled it out again.
no idea why it didn't work, perhaps due to it not fitting correctly.
i think now i'll just get someone out to look at it, don't want to do more harm than good.
well.. a coil for another engine wouldnt work, i imagine.
completely different application.
give the sanding a go before you take it anywhere. go to any nissan dealer for the springs or even a wrecking yard
the coil pack was from an R33 GTS-t which i was informed is the same as mine.
the guy looking at it tomorrow is currently putting an RB25 into a 200sx so he should know his way around ok.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
