I must be having a dumb day...........how does cleaning the injectors improve the fuel economy?  Surely a dirty injector flows less, so the fuel economy should be worse when it is cleaned and flows more.
The ECU doesn't know that the injector is dirty, it still opens and closes it according to the mapping.  In closed loop running, the ECU aims for 14.7, so it doesn't matter if the injector is dirty, 14.7 is still 14.7.
As I said, I must be just having a dumb day........
:( cheers  :D
Below is what I visualise how a clagged injector could possibly increase fuel consumption.
Say we have a clagged injector or two that atomizes badly and flows less.
The O2 sensor only views the overall afr, not the individual cylinders.
As a result one or two of the injectors will be flowing less and atomizing fuel badly.
As a result, less fuel flow in to those cylinders is going to increase the afr that is seen by the ecu via the o2 sensor.
As a result the ecu increases duty cycle slightly to bring the 'overall' afr in check.
As I said.. That's the way I visualise the inner workings. :)
I would really like to know why some rb's are better than others on fuel.
My R32 has always been decent, changed to a bigger motor and its hardly changed, not to mention its always on boost due to the small turbo that is hanging off the side of it.
I'm almost scared to swap in some larger injectors. lol
Edited by Cubes
  • 1 month later...
I finally got over 400KM on a tank of fuel, 409km and filled up before the fuel light came on. Thats a record for me!
Edit: I think the light flicked on for 1 second at some stage though. It does seem to slow up a little on takeoff with a full tank ,all that extra weight.
BEFORE the light!
WOW!
I get to about ~380 and then the lights on/off a lot, then at about 400 i get it always on and the car doesnt start very easily on a slight hill
Then at ~410, i fill up and put in 63L's
I know i push it :P
Well, just filled up. 1st FULL tank Ive used since the dynotune service with new O2 sensor.
55.8L filled it right up to max, and did 391.5km for that tank. The fuel gauge light was just starting to flicker.
That equals exactly 7kms per litre, or 14.3L per 100kms. And I was certainly using 'boost' during this 391kms!
Edited by bwilkeson
NRGIZD, like i said, i have a DFA here and built which i wont be needing anymore due to getting a power FC, they RRP at 79 in kit form, and i dont mind giving mine to you at that price built.
You will need the hand controller with it too, but they are pretty easy to build as well (i need to keep my controller for my EBC)
The DFA is also pretty easy to install, and i can also just send you right to the person that was going to tune mine with me Dr Drift.
Grab the SAFC-2 off ebay, for under $400 brand new. Cant go wrong with the Apexi...............
See thats what l was thinking, esp as the workshop l use know them very well.
Might have a sit and think on it, are the hand controllers hard to assemble?
When I first bought my stagea I was getting about 300km to 50ltrs not going over 3000rpm. (Mixed Driving, Sydney & Freeway)
Then autostyle did a service and changed spark plugs, O2 sensor, high flow filter eliment, cleaned all the throtle body, injectors, fuel filters, etc and now I'm getting about 450 to 50ltrs. Not hooning but not granny style like previously.
I also drove to QLD and was achieving 560-600km to 50ltrs.
Car is still facotry standard other than the high flow air filter element.
Given that is the first post by that ID, and their link is straight to autostyle, you have to wonder about how genuine that comment is.. Care to comment about what your association with them is, and what stagea you drive?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
