I must be having a dumb day...........how does cleaning the injectors improve the fuel economy?  Surely a dirty injector flows less, so the fuel economy should be worse when it is cleaned and flows more.
The ECU doesn't know that the injector is dirty, it still opens and closes it according to the mapping.  In closed loop running, the ECU aims for 14.7, so it doesn't matter if the injector is dirty, 14.7 is still 14.7.
As I said, I must be just having a dumb day........
:( cheers  :D
Below is what I visualise how a clagged injector could possibly increase fuel consumption.
Say we have a clagged injector or two that atomizes badly and flows less.
The O2 sensor only views the overall afr, not the individual cylinders.
As a result one or two of the injectors will be flowing less and atomizing fuel badly.
As a result, less fuel flow in to those cylinders is going to increase the afr that is seen by the ecu via the o2 sensor.
As a result the ecu increases duty cycle slightly to bring the 'overall' afr in check.
As I said.. That's the way I visualise the inner workings. :)
I would really like to know why some rb's are better than others on fuel.
My R32 has always been decent, changed to a bigger motor and its hardly changed, not to mention its always on boost due to the small turbo that is hanging off the side of it.
I'm almost scared to swap in some larger injectors. lol
Edited by Cubes
  • 1 month later...
I finally got over 400KM on a tank of fuel, 409km and filled up before the fuel light came on. Thats a record for me!
Edit: I think the light flicked on for 1 second at some stage though. It does seem to slow up a little on takeoff with a full tank ,all that extra weight.
BEFORE the light!
WOW!
I get to about ~380 and then the lights on/off a lot, then at about 400 i get it always on and the car doesnt start very easily on a slight hill
Then at ~410, i fill up and put in 63L's
I know i push it :P
Well, just filled up. 1st FULL tank Ive used since the dynotune service with new O2 sensor.
55.8L filled it right up to max, and did 391.5km for that tank. The fuel gauge light was just starting to flicker.
That equals exactly 7kms per litre, or 14.3L per 100kms. And I was certainly using 'boost' during this 391kms!
Edited by bwilkeson
NRGIZD, like i said, i have a DFA here and built which i wont be needing anymore due to getting a power FC, they RRP at 79 in kit form, and i dont mind giving mine to you at that price built.
You will need the hand controller with it too, but they are pretty easy to build as well (i need to keep my controller for my EBC)
The DFA is also pretty easy to install, and i can also just send you right to the person that was going to tune mine with me Dr Drift.
Grab the SAFC-2 off ebay, for under $400 brand new. Cant go wrong with the Apexi...............
See thats what l was thinking, esp as the workshop l use know them very well.
Might have a sit and think on it, are the hand controllers hard to assemble?
When I first bought my stagea I was getting about 300km to 50ltrs not going over 3000rpm. (Mixed Driving, Sydney & Freeway)
Then autostyle did a service and changed spark plugs, O2 sensor, high flow filter eliment, cleaned all the throtle body, injectors, fuel filters, etc and now I'm getting about 450 to 50ltrs. Not hooning but not granny style like previously.
I also drove to QLD and was achieving 560-600km to 50ltrs.
Car is still facotry standard other than the high flow air filter element.
Given that is the first post by that ID, and their link is straight to autostyle, you have to wonder about how genuine that comment is.. Care to comment about what your association with them is, and what stagea you drive?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
