Shell helix Ultra has a viscosity rating of 5W-40.
The first number indicates the viscosity of the oil at low operating temperatures, and the second indicates the viscosity grade at 100C.
Check this website for more details:
http://www.viperclub.org/articles/oilfaq.html
5W-40 is perfectly fine for Skylines, and I've noticed the Shell oils stay cleaner longer than the Mobil oils in my experience. (Not that Mobil 1 isn't good. That too stays very clean).
But I dont EVER recomend Castrol mineral oils for ANY car! That has a tendancy of getting dirty very quickly! I dont know about their synthetic oils though...
Zahos
Originally posted by INASNT
while we are on the topic, whats the item numbers/brands to use for the oil and fuel filters??
For Oil Filters, I use the Ryco Z145A (yes, the one for 300zx's and VL's).
I've also used a Valvoline one (the equivalent item number is V04 from memory).
Cheers,
David.
Originally posted by McCracken
INASNT (and everyone else), change your fuel filter asap if you haven't already.  This *cheap* little item can easily rob you of performance and economy if dirty!
i have had my car 1 1/2 years and have changed it twice already! :P
  • 2 months later...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
