;):D -HKS T51S /T51R spl turbo kit
*exaust manifold
*dump pipe
*HKS external waste gate
*HKS T51S turbo
*HKS T51R
*screamer pipe
$5500.00/HKS T51S
T51R spl $6500
to suit RB26 and the turbo
-KKK27 turbo brand new $1500 or can come as a kit for RB20 for R32 that include kkk turbo,manifold sard exteranal waste gate,dump pipe
-hks blow off vavle super seqental $200
-impuls 280km speedo brand new still in box $200
-mine speedo 320 got over 70000k on it $270
-mine computer to suit 550cc for GTR R32GTR $300
-R32 dash for two gauge after market $80
-HKS t51S turbo new $2500 used $1700
-Sard 700cc injector with hkS or with Tomei rail $1200
-Sard feul reg gold in colour $240
-Z32 AFM with plug $270 each.
call or email
.0415642296,[email protected]
Din.many more parts left
Edited by dinzlr
https://www.sau.com.au/forums/topic/81873-gtr-parts/
  • Replies 68
Interested in some of the gear, PM sent.
-HKS T51S /T51R spl turbo kit *exaust manifold
                              *dump pipe
                              *HKS T51S turbo
                              *scream pipe
                                                     $5500.00/HKS T51R spl $6500
to suit RB26 and the turbo compressor been polish
-split fire coil pack $600
-Z32 air flow meter $250
-nismo 550cc injector $500
-Sard external wastegate 55mm $700
-twin blitz blow off vavle for GTR $250
-GTR twin turbo kit with everthing $1300
-ARC air box for GTR R32 $200
-mine dash 320 got over 70000k on it $300
-mine computer to suit 550cc for GTR R32 $500
-mine dump pipe for GTR *2 $300
-HKS oil cooler for GTR $300
-osgiken cam gear suit RB $300
-Brembo break off R33 front $1200
-TD06 turbo like new $1300
and many more also copy product for cheaper price for more info or any product
you looking for please call or email
https://www.sau.com.au/forums/topic/81873-gtr-parts/#findComment-1487856
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
