I was driving along the highway last night at about 100 when the back of the car pulled really badly from left to right then drove normal again. I looked down and the HICAS light was on. I pulled over straight away and switched the car off. I checked the power steering fluid level but because i was in the middle of nowhere and it was cloudy i didn't have much light. There seemed to be enough in there but i couldn't be sure.
I jumped in and drove back home. Was almost in town and it did it again... this time it didn't throw the car around as much. Other than that it felt completely normal to drive. Steering wasn't heavy and it went around corners normally.
Its an R32 GTS-T auto. Has a aftermarket steering wheel on it with a HKB boss kit. Is the HKB boss kit HICAS compatible? The steering wheel is on straight as well.
Thanks!
Simon
https://www.sau.com.au/forums/topic/81926-hicas-problem/
There are an awful lot of threads about HICAS.....
How long is a piece of string? :D HKB make HICAS compatible boss kits, but whether or not you have the right one is hard to say without a model number or at least a picture.
Lucien.
https://www.sau.com.au/forums/topic/81926-hicas-problem/#findComment-1487438
most of the problems people have with HICAS are due to fitting an aftermarket steering wheel wihch doesn not have the correct hicas sensors.
perhaps your car deciding to steer itself at 100kms is *because* there is a problem with the boss kit?!?
https://www.sau.com.au/forums/topic/81926-hicas-problem/#findComment-1487764
:idea: Ding, ding, ding :D
Merlin is right. HICAS problems are almost always to do with either low fluid or an incorrect or incorrectly fitted boss kit.
So if you can tell us what the boss kit is, and even better, provide some pictures of the install we might be able to help.
https://www.sau.com.au/forums/topic/81926-hicas-problem/#findComment-1487791
mine did this aswell mate,
scary stuff,
with a standard steering wheel
and a full fluid level,
I just disconnected the pump at the
back of the car and all head aches
are gone
Does this cause any other problems?
Anway... found a power steering fluid leak. Checked the fluid again in daylight and found it to be only about halfway up the dipstick. Filled it up and fixed the leak but haven't had a chance to go for a squirt out of town yet.
I'm gonna assume that this was the problem and hope that its all fixed now.
That way i can get back to making it quicker!! :uh-huh:
https://www.sau.com.au/forums/topic/81926-hicas-problem/#findComment-1491324
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
