just wondering what are my rights if i find out my skylines km's are non guinene.In a issue of HPI they had a buyers guide for 32 gtrs and they said if u had a white sticxker with xxxxxx km's on it that was when your timing belt was changed.My car has done 62,000 and the sticker says 100,000 km;s.So is the odometer reading fake and what is my rights if it is fake.
https://www.sau.com.au/forums/topic/82164-non-guinene-kms-question/
look for other signs for a push back odo
eg service records, next service due sticker, timing belt been changed etc
if you have soild proof and take it back to the dealer, they would most probaley be look out a refund, if you threaten them with taken them to consumer affairs
the last thing they want is getting investergated by comsumer affair!! :wizard:
I dunoo if it makes it look like its been changed more but the tacho and the lil miliige counter thing doesnt work.It has a white sticker on the block area at the front of the rocker cover saying 100,000 km and in hpi they said thats a sticker saying wen the timing belt was changed.
its a fact that ALOT of japanese cars are wound back ,..... your with the timing bent sticker.. they all say 100000 but when they replace it they write in pen wot it was changed at and actually indent the silver label..
apparently there are alot of arabs in japan in the car market and have been informed that they do most of the winding back... what can u do ???
Yeah, sounds like its been wound back. But hey, great for re-sale value! Just look after with regular services and she will be sweet.
A mate of mine bought in a R32 '89 4dr and it showed only 46,000kms and there were tears in the interior, overall rough condition, so dont worry, your not the only one.
I have just bought a R33 GTS25t sedan which apparently has 76,000kms on the clock, who knows, perhaps thats wound back too.
100,000km sticker is when you need to change the belt. When it has been changed there will be a date and mileage it was changed at ( as said in above posts )
Virtually every car from Japan has been clocked as genuine logbooked, sevice history low km GTR's go for big money in Japan.
If you paid the usual $18K ish landed and expect it to have only 60K on the clock then I think you are a bit new to this...
Clocking speedos in Japan is a full time job and all the brokers will warn you to take the reading with a little suspicion.
Cheers
ken
if want take a pic of the sticker in hi res and post it up here, i can read it to see what it says. this can clear confusion but yeah if the price was too good to be true then reality is it probably was too good to be true...
masahiro
Yep exactly the same thing with my car ..... bought it with 70,000kms on the clock but strangely enough the service sticker had the imprints on it next service at 114,000kms or insert month here (about two months after i bought it) Then 4 months later my odo stopped working all together.
I bought it from a private person on consignment in a yard .... by the time I found the imprint of the service sticker it was too late and i was too lazy to do anything about it.
  • 3 years later...
i always thought fake km's are pretty much a mandatory thing with all imports 10 years and older.
best thing to do is assess the body work. how much grime has it biult up underneath? do the seats have old wear and tear marks?
In Japan, every 100'000kms or 5 years, its rebuild, engine swap, or trade up, that's why they have warehouses full off semi-low KM vehicles.
Imports around the 100'000km mark arent rare, but workshops are well known to wind back vehicles to a bullshit figure like 40'000 and claim they're genuine.
The only real way to check is with Japan, contacting the seller on that end, so unless the vehicle is a fresh import.
Might seem like a long shot, but hit up the internet with your VIN, or any numbers off your compliance. I traced my Cefiro's history finding old eBay links and some shit on the web, and it's not as hard as people think.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
