In a recent copy of zoom i saw a clubman wth the rb25de and its mods were custom extractors, custom plenum and computer.
I was just wondering if anyone has done anything different to their plenum in the quest for power.
Even more so if gains could be made using aftermarket plenum options such as the Greddy one with a 80mm throttle body etc? (a large outlay for minimal gain i would imagine).
BTW the car was pulling 148kw@wheels in the article, And the tuning shop that fitted/tuned the computer is local for me :rofl:
https://www.sau.com.au/forums/topic/82236-plenum-mods/
the plenum change wont give you any power increase and if it does its not worth it. $1000 odd for the greddy plenum and youll get maybe 5kw? i wouldnt even change the plenum on a 280rwkw gtst cost vs gains = pathetic. spend the $1000 on something else. the puter on the other hand, if u can get a cheapie remap done then should give u 15rkww ish maybe for $250 odd
https://www.sau.com.au/forums/topic/82236-plenum-mods/#findComment-1492008
It was theoretical question, i couldn't justify putting a 1k plenum on my N/A either as it would be better spent on my GTR. I was just curious on ppls opinions on how much of a difference it would make as i stated above. The clubman with the Rb25de was pulling 148kw at the rollers with plenum, extractors and computer....
https://www.sau.com.au/forums/topic/82236-plenum-mods/#findComment-1498744
when i was looking into different engine options i did some research and talked to my old boss (x race car mechanic) about 6 throttle bodies with tuned length trumpets. This option will give far better results then a plenum. The length and design of the trumpets will determin where and when the car makes power and torque, different options give different results. This option will increase power and torque but more notably markidly increase throttle response.
To build a highpower NA engine, internals need to be light weight, lightening pistons, lightweight rods, knifeblade the crank, all balanced correctly will allow the engine to rev quicker more freely and higher... High revs is how NA's make power, match a suitable head capable of flowing enough air for the engine and you will have a great package.
https://www.sau.com.au/forums/topic/82236-plenum-mods/#findComment-1501607
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
