not my car but in the city on thomas street (between UTS and tafe)
was walking with a few friends and saw a guy and girl look suspicously into a jeep wrangler (the ones with the plastic top)
anyways, the guy unclips/opens the top and jumps in and starts doing something (couldnt really tell as i was still walking towards the car)
alarm goes off and he quickly jumps out and they both ran away
anyways, i just called the cops to let them know (i would want someone to do the same for me) ^^
I park there all the time....either that or right in front of building 10.
From your description they just look like a bunch of amatuer joyriders........and since the wranger had a relatively easy to remove soft -top it was a prime target.
Also you should have run after them pretending it was your car just to scare the **** out of them..... :P
im always around building 10, but usually walk there as its close and i hate parking my car anywhere especially in the city because stuff like this happens,
shonen which car is yours, ill keep a lookout for it whenever im around.. the only one that comes to mind outside building 10 is a white 34 gtt with stickers on it, auto. is that yours?
heheh probably not a gd idea to post where u park your car.. lol..
Hmm i guess, your car can get stolen anywhere you park, even your garage..
But city is gettin worse these days.. esp north area.. lots of stolen cars..
Nah dude that aint mine......I dont actually go to uts but park there occassionally when im meeting up with some mates at uts.
Far out that's where I go to uni sometimes.. I see that white one too parked outside the IT building.
That's dodgy as, I always thought the places around there would be ok... especially quay street too, seeming it looks like a street with lots of cameras on it.
I have caught 2 kids stealing an Excel of all cars on my way home from work. Walked past them while they were trying to hotwire it, completely fcuking the ignition in the procees due to the fact they were complete n00b's and hadnt the slightest idea what they were doing.
I grabbed a few passers by who I knew lived in the area and we went to approch them. They spotted us coming at them, bolted to a van and drove at us, nearly running us over.
Thieving pricks
thats mine
thats mine
lol i should have known since i saw your car when i met u to buy the boost gauge off you!! oh well i know now, so ill make sure no one steals your stickers :(
btw do u do IT at uts?
IT is for wussies. Engineering is the shit. I too have seen your car there ecl.
THATS IT, ecl's car is not welcome in front of my building anymore!!!!! :lol:
engineering guys are all irrational :rolleyes:
Quite the opposite actually. We are the rational ones and are better at maths :rolleyes:
funny you say that, as i hate maths, so u might be right about that, BUT i will still stick to the fact that there is something wrong going on in most of your brains, most irrational creations or anything stupid at uni is the cause of engineering students.
:unsure:
:rolleyes:
Naaah, it's the law students that get the shit stirred up on all legal issues. Engineers drink beer and invent (or so the stereotype has it).
and meanwhile, all the IT students browse internet forums :rolleyes:
(another stereotype, which is more true for the workforce)
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
