  • Replies 275
Posted Images
Since Beer Baron doesn't have either moderation or admin rights perhaps you should find someone else to abuse.
IM PERFECTLY AWARE OF THIS AND WAS NOT ABUSING HIM JUST GIVING HIM CHEEK
HOWEVER I AM INFACT ABUSING THE PERSON THAT HAD THE POWER TO DO THE ABOVE WITHOUT INFORMING ME THAT I WAS ACTUALLY DOING SOMETHING WRONG!
Hey dude your caps lock is on :cheers:
Thanks nv033
we know that the MINES 32 in Japan has done a 10.60 with 25/30's.
Theo had the Aust record, 10.78 with 25/40's
Some guy in NZ says he has done a 10.2? with low mounts? (but this is only hear say)............so until we are proved incorrect or someone goes quicker......lets say DIRT is the fastest 25/30 :(
So unless anyone can provide any evidence otherwise, TWO06L is the fastest low mount-equipped GTR in the world?
Sweeeeeet. Congrats again. :O
Sweeeeeet. Congrats again. :(
I'm not sure that you're comparing apples to apples, I mean the Jap cars are running Nitto's and probably pump fuel. Then again their tracks are also alot slower than WSID as well.
Having said that, it in no way diminishes the results that Paul & Stacey have got with their car - at the end of the day it's a very quick time for a combination that would perform well day to day or on the circuit :O I think if Cabin/Autosalon are still doing that car of the year with track and drag testing it would kick some serious ass (with a slight change in suspension, tyres, fuel and tune for conditions).
i wouldn't call that spuring people on quite honestly!  And its not the first comment he has made with that theme... and like you can't stand half a logo, i can't stand sexist people!
As i have said previously, no comment was meant to upset anyone, and i did appologise if it had..... unfortuantely the internet doesnt convey how something is intended very well. It was only meant to be a gee up, but if you felt it wasnt i will keep comments like that to myself from now on...
now Merli, pics or ban i say!!!!!
I'm not sure how you can differentiate these things. If they want to run different radials, good luck to them, that is their choice. Pump fuel? That is not a definite and it is also their choice. And how do you quantify that their tracks are slower? None of these things realistically effect the times run in that different people choose different tyres, fuel and suspension. The main comparisons are there for all to see in so much as everything else is on a fairly level playing field.
Also, I recall a certain GTR from Japan a few years back attended a drag meet a Willowbank and couldnt run any better than its best time of 7.67 :(
Also, I recall a certain GTR from Japan a few years back attended a drag meet a Willowbank and couldnt run any better than its best time of 7.67 :O Our tracks must be longer :)
That's exactly my point - being realistic. Nittos are a slower tire, pump fuel is certainly a different brew from VP gear and WSID is classed as one of the world's quickest tracks due to surface, prep, altitude, gradient and location. The goat tracks that they run on in Japan... is just that. You don't see the Japs providing an alitude corrected time for their runs, which is one of the most blatant aspects of their strip. Even the launch surface of WSID is a calculated affair, there's no way in hell that any such thought went into what looks to be a disused air strip/part time fire trail that they run on in Japan. There was a debacle about the legitimacy of the HKS drag car's best time, since it was done in "private testing"... Oh and wasn't it raining for the majority of time the HKS car was at Willowbank? That footage of Mr. K. doing burnouts in the R33 is pretty cool. Ideal environment for record setting yes?
Heh but I know you already know these things :(
I am not really sure how grouping the 'ladies' together is meant to spur someone on? if you thrown the gauntlet down and challenge me.. fine! but making remakes like that are really unnecessary and can feel demeaning! thats all i'm saying!
merli!!!!  what tha!!!!  when do you take pics like that!!!  was that at drag day!?!?!?!?!?!?!?!?
Sure was :(
Not my fault that you have the infinite wisdom to pull such a face when a camera is pointing in your direction :lol:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
