Hey all,
I've got the following parts up for grabs:
R32 GTS-T LH Guard - Minor scratches with one small dent - $100
LH Guard
R32 GTS-T Standard front bar cover - Hairline scratches, nothing dramatic - $100
Front Bar
R33 GTS-T Series 1 bonnet - Minor scratches - $300
R33 Bonnet
R32 GTS-T Head - Contains injectors, inlet manifold and exhaust manifold - $150
R32 Head
RB20 non-turbo engine - Was going to convert to turbo but no longer doing so, unsure of milage as it came in the container - $400
Engine 1
Engine 2
Engine 3
95 Supra BOMEX front bar - Minor scratches - $150
Supra front bar
95 Supra BOMEX side skirts - small crack on one - $100 pair
Supra skirts
Any further enquiries, please feel free to post up or PM.
thanks in advance,
nuR.spec
https://www.sau.com.au/forums/topic/83224-various-parts/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
