damn I'm a sexy cross dresser
hahaha... enter your car in the mardi gras :P
OMG!!!!!!!!!!!!!!!!!  HAHAHHAHAHAHAHAA... i haven't seen that pic in ages!!!!!!  nice one ed! :D
blast from the past ;)
Look, I only told Mona to get back in the Kitchen and make me some pie ONCE.
and that should have been enough..
but no...
I am still without PIE..
:P
you need to flex your muscles to show her who's boss :lol:
  • Replies 68
I could have swarn that throughout history women have been fighting segragation for decades, not only that but traditional male institutions have been critised publicly for their single sex rules.
I would have thought that instead of seeking further segragation you would instead be seeking to raise the profiles of females and increase public knowledge of their roles within existing clubs.
Man i must be getting backwark in my years, I also heard 2 skylines talking about meeting up without their owners.... like on a regular basis.... its not cricket it tell u
goodluck with it chicky!
i run Drivn by Heels in Qld... and love it!
everyone in the club loves the club and we all get along so well.... we get heaps of support from others too.. including alot of males who like to see females in the car scene getting out there more and doing it all for themselves without always having to be in the background of the guys!
goodluck with it.. and if you need any help or have questions etc... feel free to send me a PM! ;)
goodluck! ;)
ta
jodes!
OK...im not trying to have a go at you or make a joke at your expense, just trying to give some constructive critism. But dont you think having a name like Pretty Motorsports and having shirts with PMS written on it defeats the purpose of trying to be recognised as genuine enthusiasts ?
I just think it will create the very image/impression that you girls are trying to distinguish yourselves from :D
my 2 cents.
I think change the gang name to PINK LADIES.
have bright pink Jackets, tight pants, boofy hair, too much make up...
and the rest of SAU should be changed to "T-BIRDS".
the club t-shirts should be replaced with tight white bonds t-shirts and we should all have black leather jackets.
and we should all sing.
I shall be known as "Danny Zuko"
I will need a woman to be known as Sandy... Please take a ticket and line up.
man I come up with some good ideas!!!
Now THATS!!! a good idea
can i sing love is in the air?
really?  how come nismo!?
quite simple
women can be crap at some things
i work in a workplace (admin) stuff
the workplace is 80% female, 20% male
the women are useless
totally biased, unjustified and non constructive post
cheers
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
