Hmmm.... Yeah... This is on R33 Gtst.
I tried to rewire the bleed valve my car came with and hook up the stock solenoid as a fuel consuption experiment. I hooked up everything to the solenoid and went for a drive. There was no wastegate at all :D The boost just went through the roof. I tried swapping the hoses on the solenoid but to no avail.
This is a diagram of how I did it.
  ___
|   |    --> to wastegate
|   |    -->  -------T-------- --> (cant remember)
|   |                | --> (cant remember)
|___|
Where it says (cant remember) on the diagram:
* One is where the bleed valve is hooked up at the moment
* Another is blocked off at the moment.
I am at work so I cant check any ideas straight away.
Does this sound like the solenoid is gone? Makes sense to me. If the outlet is blocked off then the wastegate would get whatever pressure is in the hose (athmospheric most likely) and will keep boosting. Can I take it apart and fix it?
https://www.sau.com.au/forums/topic/83551-is-the-boost-solenoid-dead/
Mate, I don't know what you're trying to do, but i have a few pointers.
The solenoid itself is quite restrictive, and does not let much air through.
Also, I don't know if you've like hooked it up to power etc, but just try it. Get a bit of vaccuum hosing, and blow on it when the solenoid is open and closed to test it.
id just pick up anorher solinoid dude.
Hence the sig :D I figured people should have trillions of them lying around after fitting aftermarket boost controllers. Blowing into it? Hmmm... I m not sure itll prove anything.
Blowing into the solenoid will test you've plugged it up the "right way" (i.e. for the air flow to be going the right way).
Just blow into the side your intercooler/pressure is coming from and stick your finger over the hole going to your wastegate actuator.
If you can't feel it then it's wrong and try the other way.
  ___
|   |    --> to wastegate
|___|
You have it plumbed the wrong way around. The top fitting on the R33GTST solenoid is the input (boost supply), the bottom fitting is the output (to the wastegate).
:( cheers :)
:D cheers  :(
Yeah, I am pretty sure I tried both ways, but i'll give it another go.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
