hehe nice settings i have a setting of my own.
Spring rates: jst make sure the front is lower than the rear
Ride Height: rear slightly higher than the front
Shocks/Bound/Rebound: do this according to order, 4,3 / 9, 6 must have fully customised suspension.
Camber: If u want good handling normally front is 5.5, then rear 4.5
Toe: negative 1.5
Stabilizers: Front and rear at 4
LSD: torque increase by 2, acceleration 51, decceleration 33
Oversteer stability control: Off
Understeer: depends on your taste
Traction control: Off
https://www.sau.com.au/forums/topic/83602-grand-turismo-4/#findComment-1512761
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
