Visiting Brisbane
Guest two.06l
dance scene and all that accompanies it = the family...if your into atmopshere etc you need to head into central brisbane though.
central brisbane is where we will be so whats doin' in there on Sat night?
Where is the family?? how far from where i am staying?
the valley is like a 5min taxi ride...not far at all........on a saturday night heaps happens in bris but not alot is the "harcore dance scene"...you can easily walk around the city and check out the clubs, most reside on the few main streets around queen st mall.
Guest DIRTgarage
sweet.....if any QLD'ers are keen to party with us call on 0409715622 tomm. to hook up
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
