  • Replies 47
pretty ignorant, if its 98RON, then it should be as good as the Mobil and BP stuff. I have noticed no differance in knock levels between Mobil or BP, but I tend to get less kms out of BP Ultimate
Chances are its probably comes out of the same refinery as either BP or Mobil
the SAFF on OG Road sells 100RON Racing Fuel
Im going to give it a try next time I go past a SAFF, the one I saw selling it was down near Holdens at Elizabeth
I think they take discount vouchers too.....
if your going to use the STAFF 98 ron fuel that im sure it should be ok if you got it tuned to take 98 ron fuel no matter what it comes from ie Staff/bp/mobil. But what is the point in using 100 ron fuel if you only use it once in a blue moon?
Yeah, the SAFF 98 should be no differant to the BP/Mobil fuel
100 Octane is good for track days etc where that bit of extra octane can be the differance in going home happy, or towing your car home because it had been detonating with the extra heat your car experiences at the track. It was pretty expensive though, at about $1.65 a litre I think (that was 8 months ago too)
I have used it once, and it was quite good
I think they are calling the SAFF stuff 'Boost 98' or seomthing like that
Interesting to hear people say "if it's 98 it should be just as good as the others"
Ask some questions of some people who have used optimax (not available in SA) and listen to the responses. Plenty will never use it again.
Also, I wouldn't buy fuel from a servo that didn't sell a lot of it. This high octane unleaded goes off, so if they aren't selling a lot and getting topped up frequently you might get a stale batch.
The moral of the story - always buy fuel from a busy servo.
A recent write up in a magazine found all 98ron fuels were 98, but the age of the fuel will make a difference. I think this is the big benefit with BP as they use fewer aromatics to produce 98ron, and hence it is less susceptible to the age problem.
Actually a lower sulfur content is better for your engine, cos it can form sulphuric acid and etch away in your combustion chamber when the engine is cold. It was one of the main contributors to cold start engine wear. Was reading that in a SAE paper a while back..
Edited by Busky2k
Yeah good mate. Yourself?
Oh yeah when I was surfing the SAFF website, seems this 98ROn stuff is 10% ethanol. Good for emmissions and the environment but could have unpredictable results in modified boosted cars like ours.
Edited by Busky2k
I am always looking for a positive, so another way of putting it is that the acid eats away at the combustion chamber (making it larger) and hence decompresses it allowing me to run more boost (and hence get more power without detonation). How much sulphur fuel will I need to get my RB25 up to an RB26?
The glass is always half full.
Thats good to hear, im going well.
In regards to the SAFF fuel, Im doubt their is many sa import owners with "hard" tuned cars though (correct me if im wrong).
There are always those who still haven't had a retune since Mik from Tilbrooks touched their cars (admitedly most of them dont run anymore)
Edited by 4door_Sleeper
Sorry "hard tuned" (before I edited it) meant cars with programmable ECUs that tuned to make more power than the stockie ECU. Ie leaner AFRs, more ign advance. Thus they are more succeptable to detonation from a shitty fuel. (being 'harder tuned' than factory if you get what i mean).
4door, your a crack up mate. :P In the real world, that means the clearances between your piston and bore open up due to wear. I think the rings suffered too IIRC.
Edited by Busky2k
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
