  • Replies 106
MAD_HUH - PM sent
Z00MxRACING - PM sent
platinum - Ive added you to the buyers list.
The ECR33 series 1 and 2 both use the same power fc version to suit the RB25DET.
alva - PM replied. Ive also added you to the buyers list.
Anyone want a power fc?
Think I may have over supplied the forum and theres no one left to buy one!!
....or maybe people are wondering why the price is now $20 more than the last 10 person group buy that just finished ? :P
Edited by GTTR34
Price has gone up due to exchange rates causing price increase from my supplier.
Ive searched a bit and am unable to find them for a better price.
Edited by gR33ddy
:D
BWAHAHAHAHA
i wont comment on that as i know myself how the exchange has gone up :D
One of the best price's going around guy's you should be thankfull that gR33ddy is making it easier for all of you, doing the hard work and supplying a product at a BARGAIN PRICE
Cheers B
Edited by grandmasterb
The price Paul is offerening has gone up from the last buy and as he said thats due to the exchange rate. (which i can vouch for)
His price is still one of the lowest around and i doubt that unless you know of a supplier yourself then you would not be able to get a better deal :D
Some people that i know are advertising them at alower price but then when it gets in and is stopped by customs and charged tax on, you end up paying more <_<
I have bought a bit of Paul, he is one of only a few people i would recommend as a seller and TRUST with my money.
Cheers B
grandmasterb - thanks for the support :O
masivr33 - Ive added you in and PM sent.
platinum - all sorted now. sorry about that.
d00dzc - depends if there is more interest. I'll most likely run another in a week or so and see if we can get the numbers up again.
operationsideways - No probs. Ive added you in.
We now have 9 buyers. The minimum is 10 and I have a few more interested buyers still yet to confirm.
Shouldnt be a problem getting the numbers up ;)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
