  • Replies 148
Kym thinks your all a bunch of panzy's and should git some ballz!
Yeah, i'll bring my girl along... why not ?
and as for takin pictures of the hottie's...there's no harm in it, and she doesn't mind....
I say "i'd hit it" to a good percentage of hotties i see walkin thru the shops with her right next to me!
... as long as I go home with her at the end of the day, it's all good... piss this "jewellry and chocolates" crap RIGHT OFF!
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126478
Originally posted by puckish
PVA wrote---------------------------
aka camel toe
Don't you mean Camel Hoof ? If I saw a toe like bit down there I'd be concerned.. But then again what ever turns you on PVA.
umm..... puckis.... what do we do with ya!
unless you are still a virgin or you are not familiar with the term :lol:
either way that's classic :lol: :lol: :uh-huh:
I am speachless I am without speach!
cheers
Joe
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126612
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
