  • Replies 148
I just rang the motorplex and they confirmaed that you are allowed to bring food and drinks in, but no alchol. Thats a good thing, cause I hate paying too much for shit food.
By the way, that is the most useful thing I've done all day. Think I need a rest now.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8459-motorvation/page/6/#findComment-127592
That's how these places make money, a license is not cheap therefore they force you to buy it there to cover there costs and make profit. Anyway I'll stick to soft drinks, that way I can see the chicks I'm taking photos of, when your drunk any chick looks hot.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8459-motorvation/page/6/#findComment-127630
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
