Hi guys/girls,
A strange thing happened to my car today which has caused what I believe the alternator to die on me. What happened was this morning was that I took out my battery to use it to start my brothers car (nothing out of the ordinary) and placed it back into my car and it started fine. Drove it and then when I went back to the car after a few hrs to start it, I noticed that the alternator was still ticking over when I had started the engine. Even when the ignition was placed to the On position it still keep turning over, taking the keys out still had it going.
So I started it again and it seemed as though the sound had gone but not long after I was driving it, I heard a squeeling noise which I only picked up not long after the rain has cleared but by then I saw smoke coming out of my engine bay and that was when I suddenly lost all my power. Popped the bonnet and a strange smell was coming from the alternator. Now im assuming that is dead/going as I could not start the car at all, only managed to get it started by pushing/1st gear clutch starting it. Once I got it home, it now starts but struggles alot and the same strange smell is coming from the alternator region.
Sorry for the long post but just though Id explain in detail what happened.
I just called a local auto electrician and they quoted a couple of hundred for a rebuild ;) while an importer said $140 - $150 for a 2nd hand one. BTW all alternators on r33 gtst's are the same, right?
more then likely they are all the same. Have you had a look at the wiring and plugs from there and around it. You said there was a ticking sound, i didnt know alternators made a ticking sound. You sure you arent referring to the starter motor that was ticking away?
To me it sounds like your describing the starter motor...the alternator should be turning with the engine running, but the starter shouldn't.
No havent looked at the wiring and voltage around there yet. Yes, that correct when I first when to start the car there was a continous ticking sound even though I got the car started (as though was stuck on START). realising this I turned off the ignition and pulled out the keys but keep going.
At the moment when Im starting the car I have it give it some throttle for it to start but it seems as though it wants to die on me when doing it though. Besides, once started there is a strange smell coming from the alternator region (smells like burnt electrical things) much like the same smell when the engine just shutted down and smoke coming out of engine bay when I was driving although not as strong.
Since you two suspect its the starter motor Im numb folded as to which of the two component is actually is now as Im just describing as I see it.
Hey Nozila, as they have said an altenator is driven by the engine, a starter drives the engine :P
Now I have seen starter motors lock in mesh (when they engage the ring gear) and what happens is they usually flare all the windings and are unrepairable if the engine continues to run with them engaged.
An altenator will not cause a car to keep trying to start even after you pull your keys out of the ignition. This problem can be a multitude of things, right from the electrical switch on the back of your ignition barrel, or a problem in the starter.
I have seen the copper contacts weld together in a starter motor from trying to start with very very discharged battery.
Its process of elimination mate, I wish I could help you more - but I live in North West NSW - in the bush :blink:
Cheers
Sumo
That smell you can smell is what we call at work the "dollar smell", coz you know its going to cost alot of dollars to repair :P
Sorry about me making a joke, if you handy with a spanner, pull your starter off and smell inside the nost cone, if you can smell the "dollar" smell go and get a second hand one :blink:
Cheers
Sumo
Sumo, thanks for the advice I will do just that. Unlike earlier today when the car didnt want to start at all, it now does but struggles to turn over needing the help of throttle action. Say i wanted to check the voltage on my alternator though, would i just measure the lead that is coming out of it from the back and what voltage should it be?
thanks,
duc.
the alternator sits basically in front (towards the front) of the starter motor, and its easy to think one is playing up when its the other.
I cant remember exactly, but there is a power feed going from the alternator directly to the starter solenoid.
It sounds like the starter solenoid (the small round part on top of the starter) has shagged it, and may be playing funny buggers with the alternator (due to its direct feed from the alt.)
Ive got a spare starter motor here you are welcome to try, and if it sorts your problem, you are welcome to have it for $50 :blink:
Its an easy job to get the starter out too...2 bolts, and 2 nuts....oh and a skinned knuckle or 2 :P
Use a multi meter to read the current coming out of the alternator at idle. Put hte positive lead on the cable coming out of the alternator and put the negative lead on an earthing spot. You should see about 13-13.8 volts at idle.
Hope this helps,
Deren
I just went outside to start the car and check on the voltage. Car still struggles to start but does, i measured the voltage (using a multimeter) from the lead going into the alternator (red plug over the lead) and it showed 14.5v which means that its charging the battery and thus isnt the culprit, I assume? Also, does anyone know that when my engine suddenly lost all power that it may have an adverse effect upon the engine?
Well it is high but i cant see that being a problem. Make sure all the cables an conections to and fromt he battery are all good. I had a simialr problem once where the car would just die and it was the terminal on the battery. If you have msn add me there id be happy to help more [email protected]
I can rule out the battery being dead/drained which has caused the car to stuggle when starting. As I disconnected the battery and charged it for a good few hours, whilst I was at it cleaned the battery tray/terminals, but it seems the car still struggles to start. Starting to narrow it down, 1 down 2 to go.
14.5v is fine for a cold start, once everything warms up voltage will drop to high 13's maybe flat 14's.
The regulator is designed to feed more voltage in to the battery when it is cold rather than when everything has warmed up. Its apparently the way battery's like to be charged, less volts when warm, more when cold.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
