Originally posted by JiMb0
This is just too f**king ridiculous ... I want to go get my mods engineered but now I'm too scared to even take the car on the road to the engineers workshop incase I get defected on the way there !
LOL
and the paranoia sets in. i'm engineering mine soon. let's do it together.
...umm, actually, do your mods first and then engineer yours.
  • Replies 49
the rta has a list of certified engineers. you should only get it done at those engineers as the epa might not honour a non cetified engineers certificate. can't find the url at the moment. will look for it tonight. i know it's in one of the threads in here already. just search on 'engineers' and you should be able to find it.
Morgs: when re'regoing your car the inspection station only checks things like tyres, lights, horn not bovs or big turbos etc.
400HP: My engineer can do bovs
The car came with one standard..... yes technically the factory one isnt a venting model but itll do
guys I found the list of engineering signatories and some other information
if you go the the RTA Website and then go to "Registration" -> "Vehicle Standards" -> "Information sheets" theres a PDF called vsi15.pdf.
This link may take you straight there -
RTA Docs
Jimbo: the way i see it is that you will have no chances of clearing up a defect even if the cop WAS wrong! They issue you with a defect notice, then you have to go clear it up at the rta.
a) the cop gives you an on the spot $70 fine per defect (i believe at this point you lose your 2 points too?)
B) you go to the rta and pay a further $30 to have the car inspected
Now if the cop gave you a incorrect defect, how do you prove it was incorrect and you didn't just fix the problem before goin to the RTA? The whole thing reeks of shit! I would only accept a defect and a loss of 2 points if the rta and epa were present at a defect station.....NOT just some pig taking a power trip!:cuss:
ok for all you people out there worryed about loosing points
you CAN loose points sterio exhust
not for lowered stuff like that if you do turn over the infrigment notice on the back it will say do you want to have this heard about in court you tick yes and send it away that is all you can do as of jul 1st
but you wont loose points for big turbos bov stuff like that unless the cop stuffs up
that is why there is a thing on the back of the notice
dont ask but that is what happens i know
Originally posted by gtssky
you CAN loose points sterio exhust not for lowered stuff like that
This is the issue though. What if you exhaust is right on the limit, or just under. You get defected because this cop has spectacular hearing and knows presicely what dB are being produced. You lose 2 points and $70 ... you don't touch it or alter it in any way, go to the RTA get it cleared ... thats now 2 points and $100 for an exhaust that was never over the limits in the first place ....
How is this in any way a fair system ?
and who foots the bill for the test if it comes back under the guidelines ? I don't see why citizens who abide by the rules should have to pay to prove that a member of the police force can't judge an exhausts dB with their ears ..
I'm all for the police doing their job, but I know far too many people who joined the force just to get their own back ! I'm more than happy to get a defect if I am over the dB limit, or my car is too low, or I'm running an atmo venting bov .... but I'd like the law to operate in the same way it does in other cases where one is guilty until PROVEN innocent ... This whole dealio where police only need to think something is defectable is rubbish ...
Assumption is the mother of all f**k ups, is it not ?
There are no ADR's that say things such as "big turbos are not permitted" and "no BOV's permitted"... the ADR's say stuff like "you are not permitted to alter the emissions of the car by alteration of exhaust and intake systems" or something similar.
In this way I think if you change to any non-standard items in the intake or exhaust part you are effectively changing the emissions. Turbos, BOV's, exhaust etc are all parts of the intake and exhaust and will change the emissions.... this is where it is grey...
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
