hey all,
Item:gtr interior
Item Condition:used/excellet condition
Reason for Selling:need the space
-GTR R32 REAR QTR INTERIOR LOWER PANELS: $120each OR $220pair
-GTR R32 DASH (Minus all Instruments & Glovebox): $400
-GTR R32 PLASTIC SURROUNDING (a/c, guages, stereo) Including ASHTRAY: $160
-GTR R32 SUN VISORS + REVIEW MIRROR + ROOF LIGHT UNITS + ARM HOLDERS: $100
-GTR R32 KICK PANELS: $30each
-GTR R32 COLUMN COVERS: $60
-GTR R32 ROOF LINING: OFFERS
-GTR R32 DOOR TRIMS: $160each **SOLD**
-GTR ARMREST - CONSOL: $70
-GTR R32 FRONT PILLARS: $50each
-GTR R32 INTERIOR MATS: OFFERS
Parts can be sent anywhere at Buyers expence!!
Cheers
Edited by T88 ON BOARD
https://www.sau.com.au/forums/topic/85097-gtr-r32-interior-be-quick/
if purple 32 is taking the sunvisors i am keen for the rear grab handles and the remaining kick panel. I am happy to come out and pick up :(
lwells - Vents are in perfect working condition sorry will not sell on there own sorry...
Genesis® - PM SENT
PurpleR32 - pm replied (But will not sell with out the other things)
masTers - Yes i will post up pics very shortly i just didn't have the mats with me the day i took pics.
danh - 180km/h speedo but not on sale yet
Beer Baron - Same situation as purpleR32 will not seperate package items, Kick panel is yours if still interested Send me a PM with what u want
Bl4cK32 - The covers are for the steering column
BAILED: I should have it pm me with an offer
danh: there the spotty ones I havent un packed the mats yet pics can be organised soon...Pm me if interested
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
