  • Replies 47
Hullo.... was wondering if you still have the steering wheel? I am after a standard steering wheel to pass registration. My momo one is 5mm too small to pass inspection.
Also after: genuine standard nissan R32 fuel pressure regulator
Standard front
Standard water spray/ windscreen wiper bottle
Back windscreen wiper (doesnt have to work)
Would appreciate any help! Thanks
reply either to this or email [email protected]
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1544106
Ok, I've received a few questions about the HKS piping kit. Basically it is 3" stainless steel piping to replace all the factory pieces as pictured. The piping meets the intercooler inlet/outlet and is designed for a motor that DOES NOT run air flow metres.
The orange colour in my opinion doesn't look the greatest, but it's only a paint job away from being another colour. All the piping is in good condition with no dents. I will supply all needed clamps and joins etc..
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1546639
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
