plex 15th
I think that the times all of the stock turboed cars are pulling are very impressive (Rhino, Works Auto and rev210), we are only a few tenths behind some of the guys with t3/t4's, must be that they can't drive, right Macka and Shannon? Just stirring.
It's good to see the times heading ever downward, will be nice when we can get some 11sec Skylines down at the plex and show the Trev's a thing or two.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130264
  • Replies 261
Originally posted by osc@r
haha no worries Rev. I'm lookin forward to it.
The more Skylines that are biting my tail, the more ambition I will have to go quicker. I can almost taste 12's.
If you can taste 12s, im deep throating them nightly.
4 passes of 13.1 , 13.033 13.087, 13.078
Gimme 12s damn drag god.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130652
Osc@r, Once I'm finished I expect to be pushing the 11 barrier not the 12.
The only 16" rims I've got are only 16x7, I have heaps of tyres for these, but still none for the 15".
RB20LagWagon, You were going so deep throat I thought you would gag, you'll need to get the 12 in your first couple of runs or else the clutch will end up slipping too much, but your so close.
See'ya:burnout:
Paul the Tyre Fairy
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130661
Yeah my mate said they were for a silvia, so i presume the PCD is right. Don't have any pics, can take them on monday, there are only 2, so they would only be good for the drags, but then I could score you some better tyres, got some 225/45/16's in stock.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130708
Oh i just smoked up my tires last night, i need some 17s x 235 or 245 if there is any available road or race, prefer road i spose i hate changing tyres. ill take odd sets of wheels as well as long as 4x114.3 16 or 17,s i need brakes badly
Its actually not the clutch slipping, its the pressureplate forks, getting rather hot and not being able to push the clutch face, or so i am to believe the clutch doesnt slip, it just doesnt let me get into gear
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130878
RB20LagWagon,
I have some 2x234/45/17's Bridgestone SO2's for drag use.
It's getting harder to get good stuff, but maybe next week I'll have some more, lots of people on the waiting list.
Glad to hear that your clutch is OK, hope that you can get the 12 soon.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130879
Ok i dontusually do burnouts....
hehehehheheeh but i was out woopwoop the other night and practiced my brakey so i didnt do a "hicks"
Fantastic and i smoked tho whole street...um...track....lol....however as i drove off.....click click.....goes the steel belt inner from my tyre...2 kms and 40 mins to get home hhhhhhmmmmm....
Thanks to postwhorepaul i have another bald set....thanks mate :D
as for 13 flatsssss...:shake: :shake: :shake: :shake: :shake: :shake: :shake: :shake: :shake: biatches
when u do 113mph ill be your friend
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130899
You smoked the whole street...ummm..track. Well done.
Nankangs are good for something, try not to wreck these tyress before I find you a replacement set. Then you can smoke them up till your hearts content, I've smoked them at the 'plex, once they get going the smoke is pretty good.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/9/#findComment-130969
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
