plex 15th
rev and I just make this shit up, then we watch you guys blow your cars up, haha.
No seriously, mine is through a shit-load of reading and hanging out with mechanics and tuners that do race cars and such stuff. It's amazing what you pick-up. Toluene is not bad stuff in the right dose, and if kept at 30% or below will be fine, might give you the edge you need to sneak into the 12's etc.
I'm not keen on changing the timing on the fly, but rev210 is, and he seems to do it quite sucessfully. My approach would be to add a toluene mix to you tank, have it dynoed with the timing advanced, mark where the CAS should be, then when you go down the plex you can safely adjust the timing if you run toluene.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137379
  • Replies 261
JimiH I think they just read comics!
I dont trust dynos to give proper load values, when i set up my Haltech computer on my first car the WHOLE thing was done on the road then fine tuned on dyno...
I would only change Timing on the road as this equates to realtime changes..unlike a rolling dyno
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137442
I think Macka is weighing the car down, Fat Boy Racing, lay off the beer and chips and you'll be doing mid 12's Macka.
Tuning a car on the road is a good idea, but it means that you will only hear pinging once it is quite significant. On the dyno you can get microphones to detect it at the earliest onset, and therefore do not damage the pistons.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137529
I really think you should know how to adjust the timing on the fly.
This is something fundamental that everyone should be getting their hands dirty with.
When I go to the drags I take my timing light along and do a check before I start. With wear on the timing belt and things the cas position may have to be changed slightly to get the same timing over a period.
The marking on the cas is only a guide, ALL timing should be set using the gun based on the reading you have off the crank markings. And timing ought to be set properly on the road. You can adjust it according to conditions of temperature as well.
As for knowing so much: The more I learn the more I realise I don't know very much. I get some insight for all the wasted years building cars with my mates (some for racing) and taking kilometres of skin off my knuckles.
I think there is no substitute for 'hands on' both for making you hate yourself for ever touching a spanner and understanding how things really don't work.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137534
rev210,
I agree that hands on experience is important, and I have quite often adjusted my own timing, but I still think that they should have someone with experience to show them what to do first.
I have my CAS fully retarded, so it can't move, and adjust timing via a laptop.
There are tremendous gains to be had by changing the timing for different fuels and air temperatures, but one must realsie that there is always an element of danger in playing with the timing. If your experienced like rev210 then it's not a problem, but beginners should make sure they understand the principles behind the changes they make before playing.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137546
JimiH ive been to 2 tuners and they both didnt hear pinging.....
No microphones just the one on the side of your head Paul.
A guy who was on the buffer yelled out turn it off its pinging......he was across the room!
Retarded it more......sweet......
Got home......cooler being night...good fuel.....pinging!
There goes my 296 horsepower..retard it by ear and now she runs sweet, no midrange but it is safer for me..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137744
Originally posted by osc@r
haha..
there's a couple of "little hair dryer" girls getting ever so closer to breakin the 12's fat mack..  your reign as king is to be short lived..
what u laughin at.......?
13.4 @105 is hardly anywhere near 12.9 @113
I want to see Rev and PWPaul get 13.4s on different nights :D
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137753
geez that's not good!
I thought the tuners wore those headphones so that they can hear the pinging?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137762
Originally posted by GTS-t VSPEC
rev210,
See'ya:burnout:
I should give you a fatboy sticker...haha
U would never need to change your CAS that would put your whole curve out Paul, u just need to up or down the timing at certain points in the map, Set a base timing of 15 degrees and then in the rev ranges u can run as much timing as you like!
Ud only change it if your Base timing varied from you 15degrees..
I could get back about 25hp from my 13Degrees to 18Degrees but i need to retard the top end.....cause thats where it pings, around 6000rpm
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137766
Guest KILLER-T
Well i had a bit of a play with my timing last wednesday night at the plex my first run felt slow so i advanced it by 2 deg on the fc commander did another run it was just under half a second faster so next run gave it another 1 deg advance the car was a bit faster again but i stoped there i was getting a bit worried about the amount of timing it was running at idle its about 17 deg advanced and then it goes up to 42 deg in the midd range and then starts to drop off as the boost kicks in. so by playing around with my car it managed its fastest time sofar 13.3 108mph :burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137918
Good work!
I expect you will be moving on to 12's soon?
Gotta be quicker than Macka, you don't weigh as much.:D
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137932
KillerT,
Well done on the times, very good. There are alot of gains to be had by advanceing the timing but as you increase the timing you increase the likleyhood of pinging. If you have a laptop or hand controller to adjust the timing then this beats getting out and moving the CAS.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137949
See thats getting there...
What boost were you running mate?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137988
Killer that maybe because you maybe on the border of needing an external wastegategate.
If you tramp it boost doesnt rise as quickly so you keep your dialed pressure...on the street u usually take off slower then tramp it giving more time for boost to bleed high as u go thru gears....
This is what happens to mine altho it bleeds to about .9bar not sure if it is your problem or not....
It cant be electronic, if u dial in 1.1 then you should get 1.1 no matter if it is street or strip its still the same kinda road...
A little birdy told me you snuck in a Z32 AFM and Adj fuel reg...
Another dynotune and hp reading maybe?? do tell..
GTS-t VSPEC have you any decent input into this technical conversation?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-138116
Guest KILLER-T
Yep i got the z32 afm and fuel reg it was done at barries dyno he didnt tune it up he just put it on the dyno to make sure it wasnt going to lean out. He did a power run for me and it made 304rwhp running 1.08 bar. Again the car didnt boost as hard as it does on the street the only reason i can think of is the car was dynoed in 3rd there is not as much load on the engine and i dont get as much boost up:rolleyes:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-138129
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
