Just looked at auction reports and not many marks, came through 5 times so I assume who ever bought it for you didnt want you to pay too much and pay what the seller wants.
You will need standard, wheels, exhaust, suspension and some minor panel work, nothing to much.
  • Replies 43
Yeah, I knew about the fact that it went through 5 times. J Spec were my brokers, fantstic job they did aswell :)
I NEED those STANDARD Parts! Anyone with any ideas or suggestions PLEASE PLEASE Post! :D:)
UPDATE : Suspension is half way there thanks to Sydneykid. Just need some standard fron springs.
Wheels are fine, we just need to source some R33 GTST rims.
If you can help with these parts post here or PM me
Cheers
Chris :P
Spoke to previous owner and he actually had 2 complete sets of stocker suspension, but he binned it all age ago unfortunatly, sorry :D
Oh ok, thats a bit of a shame. Thanks for finding out for me though Ska ;)
Just because I can I'm going to post what I think my Stag will look like with the 260rs Bodykit
Now:
Then:
Still I'm not a real fan of the colour. I think I might change it. We will se how the dough fines out.
I have figured out that I will have around 6 grand to spend on the Stag by the time I get my P's. What should I spend it on?
6k.
well, put it ALL aside and get a manual conversion + PFC
Otherwise if no power target
Split dump/front
High flow cat
jap brand cat back (order now..it will take a while)
DFA and IEBC
Sydney kids FULL suspension set up
then splash the other 1k on some decent tyres and some other little goodies you may want...
Heres what I came up with -
- 260rs Bodykit
- Re Spray (Standard Colours)
- Racing Seats
- Black velor re-trim
- GTT Side IC
- Jaycar Gear (Boost controller etc.)
- CGC High Flow
- Tuning
- Cam gears
- Auto Trans Cooler
- Auto Vavle Body Upgrade
So thats it, I think it added up to around $5950 or something like that. What sought of power/400m times could I achieve with this set up?
(Remember that the car already has Exhaust, Coilovers, Mags)
Cheers,
Chris :O
Forgot it already had mods
Well in the end, it really depends what you want
Look in the thread "Get a stagea into the 13's"
The way SK talks about it, if you have a target power, get parts for that target power and dont spend top dollar
The way I said was, spend top dollar on parts, and have a power target but be aware that if you want more, you wont have to change the parts to better ones...
Sooooo
I mean, you seem to not be like me and have no power target but just want more power and handling and not care about looks.
1. If exhaust isnt turbo back, get frontpipe/dump and cat (big power gains there, and bottle neck for everything else)
2. Make sure to include caster bushes and sway bars in your list, they make a BIG difference (i can only speak about swaybars for now)
3. If your going to get a cooler, i would suggest to consider a front mount. GTR cooler with custom pipes (unless GTT cooler is fine for you (~200awkw))
Else, good luck with the car :O
Thanks AlexCim, had a look at the thread and am now left wondering, if I was to go for the GTR intercooler, what are its limits? How many kw's atw's can be obtained from it? :)
Edited by Stagea RS-Four
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
